ADVERTISE HERE - FREE TRIAL
how to remove counter tops/Formica?
Bill Tindall
Tomorrow morning the rock people show up and I am to have the old counter tops removed so measurements can be made. Not at all clear why the tops need to be removed, but they insisted this be the case. I thought it best to remove the Formica (with a heat gun?) and then pull the coated nails holding down the plywood.
Suggestions?
Aside: the rock people have put the hurt on the Corian people. The Corian quote I got 2 years ago was reduced 30% when I was requoted last week. But wife decided on rock instead of Corian. It was not much more.
Re: how to remove counter tops/Formica?
Joseph Mulherin, Sr
Bill, I think they want the top removed to the basic cabinet frame. You can look underneath and unscrew the top and then remove the entire top.
mdclor
I agree with Joe. The entire top needs to be removed so they can make templates to cut the store so it will precisely match your walls, angles, etc.
Agreed
Nat Robison
Take the whole thing off......shouldn't take more than a few minutes cutting through caulk and backing out screws. The new counter will completely replace what's there.
not that easy
Bill Tindall
I gather tops are normally attached like a table top with screws from inside the frame?
I put the tops on. I affixed 3/4" plywood to the ash frames with a multitude of coated nails. Then added Formica. The coated nails are not going to release from the ash easily so I presume I will need to remove Formica and use nail puller/cats paw to remove nails. Alternative would be to sledge hammer the tops in an upward direction and hope the frames held together.
Re: not that easy
norm knoxville
Bill, I have used a heat gun to loosen the contact cement seal. Once you get one edge started it goes pretty quick. Norm
Re: not that easy
Joseph Mulherin, Sr
Since you "built" the original top and know how it is adhered, I have to agree with Norm on removing the Formica, then you can use the nailclaw to remove them.
It is going to be a messy way of doing things, but remodeling is no picnic, but the end results will be satisfying. Good luck....
Lawrence
We had our cabinets measured last week for new Quartz countertops and all we had to do was remove everything on the old countertops. They used laser imaging to do the measurements. Took about an hour. Even measured the walls for ripples so that the new backsplashes will fit snugly against the walls. Old Castle Surfacing out of Atlanta did the measurements and will install the countertops. Home Depot where we bought the countertops contracts out the installation to Old Castle. In the paperwork from Home Depot, we were told to remove the old countertops but Old Castle said that was not necessary, just remove everything off the surface. Lawrence in SC
Reciprocating saw?
mdclor
Would you be able to pry the counter top up from underneath enough to get at the nails with a reciprocating saw? Another option would be to cut through the top to make a cut out the size of the inside of the cabinet, then you would have more room to use the reciprocating saw.
Maybe just a crazy idea......
Clint Searl
Four pound hammer
Clint Searl
heat gun and wedges
Bill Tindall
I made some two foot taper wedges. Got edge started with putty knife and pushed in wedges. I was surprised how hot it needed to be to release. It took about two hours to lift 40 sq ft. It was glued with solvent based Formica brand adhesive and by golly it was stuck. After removing about 60 nails( I think I over did the nailing) the tops came off.
Richard McComas
Why would anyone put a counter top on like that?
FredD
Not to mention taking two hours to get it off.
With a helper if you have one , it would be about a ten to twenty minute job with a couple of cans of Lighter fluid.
This works fine with any contact glue , all you do is get a edge lifted enough to squirt a little Lighter fluid under the plastic and it will come off as fast as you can pull it , all the while keeping it damp with the Lighter Fluid.
FredD
To answer your question....
Bill Tindall
It is 1992 and the best kitchen counter top material to have found its way to E. TN is Formica brand plastic laminate. (it has held up fine for 18 years in a well used kitchen) This stuff is glued with contact cement to 3/4" particle board or plywood to make a counter top . The process is to scribe the plywood to the walls, fasten by some means plywood to cabinet frames, scribe Formica to walls, glue down Formica leaving overhand at counter lip, trim counter lip edge (I have left out some steps not relevant to your question.) Furthermore, at the time one would only anticipate renewing the counter tops with Formica, in which case the Formica is removed by heat or solvent and new Formica installed as described above without removing the plywood.
So, in 1992 going back to step 2 and not imagining ever needing to remove the plywood from the cabinets, everyone one I knew nailed the plywood or flakeboard to the cabinet frames. It was quick, easy and secure. How would you have done it?
Re: To answer your question....
Joseph Mulherin, Sr
I would have applied corner blocks to the frame corners, then screwed thru them into the plywood top, then applied the Formica. Doing it the way you did is just so much DIY cheap way and quick....and not the right way to install counter tops. Enough said...
David Hay Denver
This is how our kitchen countertops were made as well (early 1980s house). Plywood was nailed to the cabinets and formica added afterwards.
When we replaced the countertops with new formica, we carefully banged on them with a heavy hammer and levered them off the cabinets with a pry-bar. The cabinets don't seem to be any worse for the wear as a result.
Needless to say, when I installed the new countertop, I screwed them down from the underside so the could be more easily removed in the future.
David
From an old "pro"..
Terry Alexander
Yep....in college I worked for a floor covering place full time, took classes at night. We're talking about the 70's. Then, floor covering stores did everything. Thus I did a ton of carpet, vinyl, linoleum, hard wood, and laminated plastic. The building industry was very "segregated" in duties. The cabinet guys put on the cabinet tops (MDF or Plywood...whatever was available). The "formica" guys installed the countertops. Contact cement (the flammable intoxicating type). We did on occasion have to remove a countertop. For this we had on old "pump style" oil can and we filled it with lacquer thinner...which we always had on the truck. Squirt and lift...squirt and lift....over and over. Make sure all pilot lights in the house were off. This stuff was pretty intoxicating also!
I can still install laminated plastic better and faster with hand tools (no routers.....on a lot of jobs we didn't have electricity) than most anybody can do with power tools.
FYI...we had another competitor that did "formica" (as noted here....formica is a name brand..but everybody called laminated plastic formica just like all refrigerators were frigidaires)....he was a smoker. Yep....you see this one coming.....laid his cigarette on the counter.....forgot about it,...and WHOOSH!
Ah...memories.
Terry Alexander in West Texas
Keith Newton----Little Rock, Arkansas
Bill, I have removed quite a bit of plastic lam. I have done it with chemicals, but the heat gun is my preference.
Start by putting heat on the topside, while getting a knife or some other long blade under the edge. I ended up buying a cheap sword from a hardware / everything store. After it comes up a little ways, I like to stick the heat-gun into the gap underneath.
It really helps to have two people. One pulling up, then the swordsman can play the heat side to side, while slicing the strings, and stabbing the blade in and rotating it to add leverage. A machete would be fine for slicing, but the fat end would be too hard on the wrist, for someone my and your age. Well my age anyway.
However, If the added height is not a problem, there is no reason that you couldn't just pull or saw off the front lip, and leave the rest on. There is no reason that the stone can't sit right on top, if you can find a way to finish out the front edge detail.
The stone guys seem to be stuck in rut for doing their work just one way. If you are the architect / interior designer, they can do whatever you tell them that you want.
I for one, like more overhang than the local stone guys always try to sell, and putting a piece of trim between the top drawer, would be easier than what you are preparing to do.
The only problem that could arise, is where they have joints where two parts come together, may need a wedge to get them flush, but that can be done by cutting a hole along that line, so they can reach back there and insert them from underneath.
we got measured this afternoon
Bill Tindall
Now I see why the tops needed to be off. I will not be able to describe the process details but in the end the person left with the outline of each unit, and the wall it abutted, constructed from strips of 1/4" plywood and thoroughly cross braced so as to hold their shape. The result was a template, the outline to which the stone would be fabricated. The process involved initially screwing these strips along the edge of the cabinet frame tops. Hence the need to have the frame tops exposed/counter tops off. He will be back Friday to install the rock. In the mean time I am to relevel the cabinets so the tops will be in one plane so there will be no tension on the rock.
FredD
In 1992 and in probably most of the country, Post formed one piece Formica countertops had been available for at least twenty years and are a snap to install.
The process you describe was the one use by Linoleum installers a long time ago and for a long time the Linoleum Union on the east Coast had countertops in their jurisdiction.
Like I said , a long time ago.
It's nice to upgrade to stone, not easily damaged like plastic tops.
FredD
