WoodCentral Articles to the Rescue!!!
Thomas Norton
Iwas working on the new fireplace surround uesterday afternoon and had planned to use a piece of large cove molding for one of the details. I had an 8' piece in the lumber rack and thought "That will be more than enough." It was left over from a custom made run.
So I cut my long piece with both mitres being very careful not to waste any. But when I went to do my returns I ended up short by 2"!! So what to do? I really liked the look but it was Saturday afternoon AND I di not relish having more run and spending the $40-50 for a set-up at the mill on Monday. And I wanted to finish this weekend.
So I did a search in WoodCentral Articles on Tablesaw Cove Molding. I knew about the procedure but never had the need to try it. Let me tell you that it work great! I used poplar and had a rip blade on my saw and with a few minutes of sanding I was good to go. Now I did make a few sample/test cuts but it was quite easy to get it dialed in.
Those "old articles " are worth there weight in gold. Or in my case milling charges!!
Re: WoodCentral Articles to the Rescue!!!
Thanks for the plug, Tom!
There are definitely a lot of excellent articles lurking in our archives here. Glad you found what you needed.
