Bowed panel
mdclor
I know this has been answered previously, but I haven't been able to find it.
I have a panel that is bowed slightly. To flatten it, do I apply water to the concave side or the convex side?
TIA,
Merle
Bowed panel
mdclor
TIA,
Merle
risky adding water
Bill Tindall
First I would consider whether I need to flatten the panel. If it will be held in a frame then don't worry about it. Let the frame straighten it.
I don't like adding water to wood. Moisture ok, but not water.
To flatten you need to expand the concave side (that be inside the curve). Adding moisture expands, so add moisture to the concave side. This is best done by wetting a sheet of newspaper and putting a layer of dry newspaper over this wet sheet(or two). Lay the panel on the stack, concave side down, bow up. In minutes it will flatten if it is not bowed severely.
Or heat the convex side with a hair drier.
Re: Bowed panel
George Colonel's Workshop-Havertown PA
Good Evening Merle,
That happens to me every time I glue up a panel. I do what Bill suggests. It wuill flatten out, and as soon as it does, I slip it into its frame. the frame holds it flat enough for use. In the Summer, its easier to put the panel on the grass so that it picks up moisture from the ground while the heat from the sun shrinks the exposed side.
George
Re: Bowed panel
mdclor
Bill, thanks for the procedure. I will give it a try.
Re: Bowed panel
Dick Coers
The only time I've had panel bow, was when I left them flat stacked on a bench or the floor. The top of the top panel picked up moisture (or lost moisture if winter) from a rapid change due to weather. Now I stand them up so air can circulate all around the panel if it has to sit for a few days. If that happened to you, just let it sit around a couple days so air can circulate all around it. It may settle down by itself.
A major problem with gluing up panels is with your jointer fence. I was taught to cancel out any vertical fence issues by flipping every other face of the boards. At a single joint, the good face is against the fence on one board, the bad face is against the fence on the next board. This really makes a difference.
Re: Bowed panel
FredD
Another way to achieve what Dick suggests assuming you haven't kept your jointer fence square to the table is to hold two boards with the good faces registering against each other and run them at the same time.
No flipping required and it is easier to remember.
Perfect every every time.
FredD
Re: Bowed panel
Keith Newton----Little Rock, Arkansas
I don't like adding moisture to wood. It helps to know if the bow or cup occured from gaining or loosing MC from one side or the other.
But even if you don't know, the same results as wetting one side can be gained by heating the other side.
If you have a stove of a sort producing radiant heat, just stand it where the convex side is getting warmed.
Another way, is to just make a tent or box by standing panels to form a small space, with a space heater blowing inside. Leave the concave side down, with the convex side up to the warm air, which will dry out that face without changing the other.
