Sometimes hand tools can be a pleasure to use *LINK*
Dave Paine
A few months ago I was pondering about whether to purchase a decent crosscut saw for the occasions when I want to do a had cut. I have an old Stanley which takes a lot of elbow grease.
I read a post about a person trying out a new Lee Valley dovetail saw and admiring the feel in the hand. I went to take a look and purchased the Crosscut version.
Today I needed to cut some pieces out of a 3in x 1in x 10ft piece of oak. Not enough room to use the table saw, too much work to clear out items which were blocking using the compound mitre saw or the radial arm saw so picked up the LV crosscut.
As the earlier post mentioned, this just feels good to hold. A few seconds to make the cut. Less messy than a power saw. Dust just feel to the floor.
Sometimes hand tools can be faster than power. A good design can be a pleasure to use. I will now be looking forward to using this saw again.
Upcoming project to install some window trim which needs to be fitted to some inconsistent window framing.
http://www.leevalley.com/US/wood/page.aspx?p=64007&cat=1,42884
Re: Sometimes hand tools can be a pleasure to use *LINK*
Have we got a deal for you!!
Bruce, a MN Galoot
You're right. Hand tools are pleasurable, and there's a whole segment of this web site, the quiet side, who are there to agree with you and welcome you with open arms :D
Welcome to the slippery slope. That is a very nice saw. I have it.
David Barnett
"Lasciate ogni speranza voi ch'entrate"
David Barnett
-- canto III, line 9, or "what Bruce said".
My cross cut saw
Bill Tindall
I don't work so very much lumber now days that it is worth the space to set up a place for breaking down lumber into cuttings. I found that one of these saws, which are readily obtainable and easily sharpened by those of us challenged by cross cut saw sharpening, are ideal for cutting lumber to rough lengths. The cut is only slightly more coarse than a real cross cut saw and it mows through 8/4 stock quickly. If I have but 2-3 boards to break down I can do it with this saw quicker than getting out the chop saw, which is noisy and throws dust everywhere.
If you want to try one, find one with a blade not severely pitted and a more narrow blade (1 1/2") than some have.
Alas, "Dante's Inferno"
Mike Farinella
Spence
Re: My cross cut saw
Spence
Bill I have a couple of these saws. Any idea where I can get replacement blades for them?
Thanks!
Spence
no idea
Bill Tindall
I kept my eyes peeled until I found one with a blade that wasn't uselessly pitted. Eventually I found one with a nearly new blade. New blades may be filed with the cutting teeth straight across which is useless. They are easily sharpened with a large triangular file after jointing. One only needs a small amount of set for KD lumber usage. They really are sweet for bucking a board to rough lengths.
Spence
Re: no idea
Spence
Thanks for the info Bill I'll keep an eye out then. :)
FredD
Nordic Saw and Tool in Turlock , Ca.
For everything needed to cut wood, they make it.
FredD
Alexandre Grigoriev
Hardware stores have those saws with a steel tube frame. Yoyu can buy one just for the blade. They are cheap.
not correct
Bill Tindall
The blade in this saw is 1 1/2" wide and thicker than the blades you are referring to. Furthermore the blades you are referring to have hardened teeth that make them impossible to reset (I have successfully filed them). They come from the store with the teeth improperly filed to boot. If you can find a Sanvick version they are good blades but they are an alternate bevel pattern without the rakers.
The saw I describe will saw much faster than the "hardware bow saws" because the teeth are properly sharpened and the saw is heavier, and, it will saw straighter because of the wider stiffer blade.
The hardware blades will not work well in my saw because these blades are too flimsy for the weight of the frame.
