REAL MILK PAINT
Fluorescent Shop Lights keep burning out.
Alan Young
Alan Young
My main basement shop lights are 4 ft fluorescent bulbs in paired fixtures.
What factors cause the bulbs or fixtures to burn out?
Re: Fluorescent Shop Lights keep burning out.
Clint Searl
Bad ballast(s)
Clint Searl
del schisler
the bulbs should last a long time . depends on the use. They are made cheep what brand ? Most will get the black end's and not come on right away. I use sylvania day lite if i can find them. Now at the box store's i don't know what brand's . Some may be real cheep made. They just go bad for no reason. Just like the bulb's in the screw in fixtures. Now as far as the ballast's go they will just open up no power to bulbs . Or burn up due to shorted winding's in the unit. You will know when this is happening. the smell . If you have a volt meter measure the voltage and see what it is. That porbly not the problum .Just the luck of the draw on bulb going bad unless they last a month ?? Than check voltage. Mine in my shop have been in their for I know 10 yrs or more i don't use them every day. Plunty of light in the shop.
Alan Young
I don't smell the ballasts.
Alan Young
I am suspecting just really cheap fixtures....
DavesNotHere
The only time I've had florescent tubes die a premature death is when I've inadvertently smacked the fixture with something.
I should add that.................
DavesNotHere
I should add that it usually takes a few days for the tubes to burn out after the fixture got smacked.
I agree- similar experience
Bill Tindall
A failing ballast will fail to light a lamp that otherwise would light with a good ballast. My fist sign of failing ballast (old fashioned kind) is that I need almost new lamps to get them to light. I have never had an electronic ballast fail, so I don't know what they do when they approach death's door.
George Colonel's Workshop-Havertown PA
Good Evening Alan,
I have 28 bulbs burning in both shop rooms in 14 double 48" fixtures. I get "reasonable" life from them, and usually buy strictly by price. My trick is to have two or three extra tubes on hand. Replace them and forget them. My fixtures are not top of the line. In the eight or nine years we've been in this house, I have never replaced a ballast. I'm lucky, I guess.
George
Cheap Fixtures
Stuart Johnson
I bought 9 "shop" rated fixtures from Lowe's and replaced two when I was still able to find the receipt. Since then I have replaced 4 ballasts in less than two years. The replacement ballast from an electrical supplier cost almost as much as the original fixtures but I have had no failures. The rest of my shop lights are coming from the electrical supplier. The ballast is the heart and cheaper will not save money.
Don Evans
One of the most important things to make sure of with these fixtures and the bulbs you are using is to check the spec's on the ballast and make sure you are not using bulbs that the wattage is rated too high for the ballast.
Making sure of this will stop lots of premature bulb failures, humming fixture, etc.
Don
Re: Cheap Fixtures
Phil Joines
I get better prices on bulbs from the local (Dealers Electric) than the borgs.
40 watt is the highest ??
del schisler
Re: 40 watt is the highest ??
Don Evans
If you are asking (saying) that a ballast will only handle 40 total watts of bulbs then that isn't correct.
You may be looking at the power usage of the ballast itself.
It's been a while since I have done any of this, but I discovered this trying to fix a horrible hum from 4 double bulb 8 foot fixtures. The bulbs that contractor had picked up to use in these cheapest Lowes fixtures that Lowes sold was humming so bad I was going more nuts than I am. Anyway, the bulbs were 75 watts each, the ballast were designed to support only half that. Went to Lowes and found ballast in stock that were much higher rated, NO more hum and bulbs haven't been changed since, that was 3 years or more ago. I continued to use the same 75 watts bulbs that were in fixture when I replaced the ballast.
The old ballast and the new ones were both electronic type.
Don
