weights for base
weights for base
weights for base
Jon
Hi, when I was young my dad and I would turn candlsticks and lamps, and lathe a groove into the primeter of the base. We then would melt damaged lead tire weights we got for next to nothing, and poured it into the groove to add stability before gluing felt on the bottom. With the health problems associated with lead and its unavailability, are there any good current alternatives to this technique?
Re: weights for base
FredD
Gold ?? Kidding of course, how about depleted power plant fuel rods, you wouldn't need a bulb for the glow , ducking and running.
You encapsulated it , I wouldn't worry about it.
Clint Searl
Mercury
Clint Searl
:D :D
Use what they use for to add weight
Gary Smyth
for cheap sculpture. Plaster.
there's a problem?
Bill Tindall
What would be the problem with doing what you have done in the past? I have no trouble buying lead at the junk yard to cast sinkers and rifle balls.
Galen Vetterick
Steel shot set in epoxy.
Steel balls or roller type from implement or automotive dealers old worn out bearing pile.
Plugs just cut from steel rounds.
Cold rolled rings from light steel rod.
Steel fab shop punch dropouts can get for free in some cases.
Nuts, bolts or washers.
Fish sinker and black powder lead balls if you must buy.
I just look at what I got handy depending on shape and number needed.
I'm less of a junk collector than I use to be. I think.
Re: there's a problem?
Bill Howatt
Lead is now one of those "don't use it anymore" items. Being banned as wheel balancing weights, fish weights, bird shot, whatever in various jurisdictions.
Bill
Galen has good ideas. However I pick up wheel weights off the road while I'm walking the dog and just use those. I turn a groove then fill the groove with melted lead. It shrinks as it cools so I leave enough room over it to add epoxy. This piece was out of balance very slightly so I put lead in the bottom to make it more stable. We had a competition to see who could make something out of a 1 foot piece of 2x4. This is what I made.
Guess what we use here in the desert!
Jesse Cloud
Yup, good old Sonoran desert sand, aka ground up quartz and granite. Weighs a ton and its cheap as dirt. ;)
Galen Vetterick
John
You must have rough roads to be able to pick up wheel weights off the road. Maybe I'd better go dig some extra pot holes. I still cast my own bullets with a Lee production lead pot. It's getting harder to get lead to keep up my supply. They seem to be stealing ANY metal that is not tied down. Even stealing cast manhole covers for scrap metal around here! Wire right off the poles.
