Timberlok fastener opinion *LINK*
I'm going to be fastening some corbels to a half wall. I was thinking about using Timberlok screws to fasten the corbels.
The corbels will be supporting roughly half of a granite counter top. The rest of the counter top will be supported by the wall.
These screw/lags are readily available at the building supply stores and at Home Depot. I can easily conceal any screw holes with 1/2" plugs. I figure if they can hold up a deck ledger board, they can hold up a corbel and a granite counter top.
By my reading, one screw should easily support each corbel (total of five corbels) and the granite counter top.
Do you think these (Timberlok) screws are adequate for the job?
Do ya'll think I should use two of per corbel or is one screw adequate?
Timberlok screws
Re: Timberlok fastener opinion *LINK*
Dave Paine
I have some of these, but so far I have not ended up with a need. Nice length and threaded about 30% since intended to be going through some wood and then into second piece.
I have sheared more lag screws than I ever expected. These claim to have more shear strength, which is desirable. Easy with today's cordless tools to create a large shear force when installing.
I think the screws can take the load, but not sure what species they are being screwed into.
I generally over design. For what you are doing, the cost of two screws per corbel will not be any real expense, and will provide a lot more assurance that the granite top will stay where it should.
They're pretty doggoned strong. My son and I have used them for structural framing attachments on a house - stronger in that application than 16d nails. My biggest concern with them for the application you're talking about is that the head design doesn't spread load terribly well, relative to the strength of the fastener. If you're using a really soft wood like Ponderosa pine, they might, just might, slowly begin to pull through the wood. In that case, I'd experiment, and see if I could find a washer with a hole the right size to mate to the fastener but smaller enough diameter to go in your counterbore. If the corbels are SYP, Doug fir, or a hardwood, I wouldn't worry.
I've installed them with a 1/2" drill, although the common tool is one of those little impact drivers. If you're lacking such tools, a regular old socket and ratchet would do the job if you predrill your corbels and eat your Wheaties.
Get your length right so that the threaded portion is buried in the framing members into which you're screwing them.
You mention that they're supporting half of a granite counter. The relative weight of the counter may not be much, but remember that you're also supporting all of the weight of the teenagers who will inevitably lean on the counter as if all their bones have dissolved.
I suspect the "data" the quote is a bit skewed in their favor. (Why wouldn't it be?) My ancient recollection is that the shear strength of a fastener is largely related to the shaft diameter. This assumes that the steel is significantly stronger than the wood and that the wood will fail or compress as it puts enough load on the fastener shear it. So the shaft diameter equates to bearing surface. So, I am a little skeptical about them being stronger than larger lags, but that does not mean they won't be strong enough for this job.
Dave, I think you are talking about rotary shear, not shear perpendicular to the shaft.
And I agree with Bill, I think a washer would be a good idea in soft wood.
As a Home Inspector and "old fuddy duddy", I am starting to see these on decks and I am skeptical. Google Deck Collapse and you will find that deck fasteners need to be taken seriously.
I would use two in each corbel with washers, but then I am and old....
Thanks, will use two.
The corbels are solid maple dressed down to 2" thick. They are 2" thick, 8" high and about 8" deep. The "platforms" or bases for the corbels are also solid maple (7/8" thick and 3" wide).
They will be screwed into 2 x 6 spruce studs.
