Keller Dovetail Jig
Thomas Norton
I am looking at the Keller jig but cannot seem to find any videos.
Anyone have any leads??
Keller Dovetail Jig
Thomas Norton
Keller Dovetail Jig Video here link *LINK*
del schisler
here is the link for the keller system
http://www.handbooklive.com/product/248/
recommendation
Bill Tindall
It is a great tool for mass produced through dovetails. Very quick and reliable. Trivial set up once it is mounted correctly on backer piece the first time.
Re: recommendation
BilWil
I have one of the plastic models and am very pleased with it.
Re: Keller Dovetail Jig
Ray Newman
I have the aluminum 16" and 24" template models. 'Musta' bought 'em 25 years ago by know. The Keller works well and is relatively easy to set up.
I have not cut variable spaced dovetails with either template, so I can't say how easy or accurately that method is.
The short instructional video is well worth the nine dollar costs.
Would I purchase them again?: yes!
FredD
You can't buy a better Dovetail jig and if your going to do frequent Dovetails , I highly recommend the Pro set which is a Pin jig and Tail jig mounted separately on four inch angle iron.
I use two routers with this setup , allowing me to quickly check set up which like Bill says is trivial.
This setup is permanently mounted to a bench , if you need a pic and are interested , I can post one for you.
FredD
Thomas Norton
Fred,
If you could I would appreciate a pic or two.
Thanks!
FredD
Here you go Thomas and you also Henry.
http://picasaweb.google.com/FredD17209/MyPictures?feat=directlink
FredD
Thomas Norton
Thanks! Quick question .Where did you get the "clamps"?
Thanks, Fred. I assume the angle is aftermarket?
Henry Higginbotham
I don't see it on the Keller site, so I assume that was your idea.
FredD
Clamps are furnished by Keller for that particular setup and the angle was after market Henry.
FredD
