Tenon problem. Why does this happen
Joe in a Cleveland suburb
I was cutting tenons on a few table aprons. The surface around the shoulders is not consistent. Hopefully you see what I am talking about in the pictures below. I've had this happen in the past, not sure why.
Any ideas on why. I will need to trim off a hair to get them to sit flush in the mortises. Not sure of the best approach to correct and salvage these aprons. Taking a little off and making them (a tad bit) shorter is not a problem.
I did these tenons on the table saw. I used my Freud stacked dado set. I had the height set based on scrap and a nice fit to the mortises. I had a block clamped to the rip fence so the piece was not against the rip fence while being cut. I did all the pieces this way. Nothing moved. The only thing that moved was the blade height for the top and bottom shoulders.
Oh, and I believe the rip fence is parallel to the blade, the mitre gauge is square, and the blade is square to the table.
One of the aprons came out fine, two did not.
Thanks for any suggestion/help.
) before you had a chance to cut the tenons. I've sometimes suspected this after cutting a set of tenons on identical stock with no problems, then suddenly had a bad one. Sure, it could have been me losing focus on what I was doing (seems to happen more often with age
), but I wonder... . Anyway, more food for thought.
