Wood Choice? a large rustic kitchen table
Henry (Raleigh, NC)
I have a request to make a 10' long rustic kitchen table. In short, my question is what wood species should I consider, given that oak is out?
More detail:
This will be a daily user table, as well as place to entertain/host (no formal dining room). They want a double pedestal style with a thick top, 2" or more. Finish is to be robust and durable ("no open crevices for food bits in between planks") with "not necessarily a distressed" look, but a rustic country/mountain/washed-out/pickled-stain kind of a look. Chair choice has not been made - but they have ideas. They want a matching/similar bench for the window side of the table. A more complete description of the house is given below.
I have great latitude in style and material choices, knowing what I think the end-goal is. Traditional furniture woods don't really make sense to me here:
- Oak is out (customer)
- Cherry is not my choice for "base color" reasons.
- Maple - tight grain makes it poor choice for the washed out / pickled stain look (I think).
- Walnut - a possibility, but no experience with it. I thought it was also tight grained and therefore may not be good choice for the desired type of finish.
Other species?
- Cypress - The porch is framed and bordered with thick cypress 'beams' but my scratch test on underside of a railing showed it to be fairly easy to dent with my pencil.
- Beech, soft maple, poplar, and maybe one other species are available at local supplier in 8/4 or thicker material.
1. Is there a pine species hard enough to use for daily use table? Southern Yellow Pine is hard enough I think, but the yellow base color would be a challenge.
2. Is poplar dense/hard enough for table application (my sense without looking up numbers is that it is not).
So what species should I consider?
Henry
hwynands@ieee.org
Here's my best description of the house setting:
This is in a home that borders on a 'mountain house' style (open layout, huge back windows, some exposed beams, rustic pine cathedral ceilings in large open 'living room' with large stone fire place, 10' or more ceiling everywhere else). The adjoining kitchen is U shaped with the opening of the U facing the back windows and the table location. Cabinets have flat panel doors (no arched top) in a dark cherry/mahogany finish, and the central island has oak doors with a subtle pickled stain. The panels on the ends of the island are beadboard with the same pickled stain, and two 5-6" diameter turned columns to support the overhang and bar stool eating area. This turned column and bar stool portion of the island faces the table area.
Re: Wood Choice? a large rustic kitchen table
Re: Hickory
Al Stokka - Cambridge, Iowa
Al's recommendation of Hickory is a good one. But another popular "rustic" wood is re-claimed wormy chestnut. It has lots of chararcter and great for rustic furniture.
Tom
John Veerkamp
Another good choice would be locust, either black or honey are great. Depending on where you are, go to a local sawmill where you may be able to find elm and other local woods.
FredD
It seems to me that Pecan or Hickory would fit your criteria. It ranges from clear to knotty and everything in between. Very hard and heavy and witrh a light stain looks like this
http://picasaweb.google.com/FredD17209/TripleDresser?feat=directlink
Bill Tindall
It is not clear why maple was rejected and maple is a traditional wood for this application. Just finished natural it will age to an amber. Or, with a white pigment stain it can be made light grey or white. Finished with a white stain and dull lacquer it was a popular kitchen cabinet material a few years ago.
Knotty white pine would also be a traditional choice for this kind of table. You claim "rustic" so what is the problem if it gets a dent or two over time? There were gagillions of knotty pine trestle tables built some years back. There was a great demand for 8/4 and 10/4 knotty white pine for this application.
"Wormy" soft maple would be interesting and informal. I have seen some nice informal tables made from this choice. You fill the holes with bondo before finishing, or colored epoxy for contrast. There is a place in Berea, KY that cranks these out and they are in demand.
Hickory heart wood will be reddish, the sap wood white. Not greatly different from ash. "Pecky" Pecan (hickory) would add some informality if this grade is still available. It was popular some years ago.
Henry (Raleigh, NC)
Maple is not 'rejected', I just did not see it as a great choice.
Thanks for making me rethink my possibilities.
Henry
Clint Searl
White Ash
Clint Searl
Beautiful, tough, durable, stable, works well, and takes a great finish. For a pickled look you might consider staining with a mix of artists' oils thinned with naptha and a bit of drier, under a CAB acrylic lacquer. Sounds like a fun project.
Clint
Re: White Ash
FredD
White Ash as Clint suggest is a great wood to have a limed Oak effect on and is easily done with McCloskey's Limed Oak Finish , clear coated with precat Lacquer in the water white version, not water base , but clear as water , hence the name.
FredD
