something is eating my cherry door
les winter
This door is under my kitchen sink. The rails and stiles are cherry, the panel is maple ply. The finish is Lee Valley polymerized tung oil. This is the only door in the kitchen with this problem. What is that awful looking staining stuff growing there and what should I do about it?
Suggestions appreciated.
thanks
les
Re: something is eating my cherry door
Lee Grindinger
I'd like a bigger view
Lee Grindinger
I suspect it's something on someone's hands or clothing, like a cleaning product, but a bigger view would help us see just where it is the scheme of things.
Re: I'd like a bigger view
les winter
like this?
Lee Grindinger
I'll venture a guess
Lee Grindinger
I'll guess you and/or your wife uses rubber gloves and recently used a product containing lye, such as a drain cleaner. Lye contains a harsh oxidizer and the darkening of the cherry looks just like oxidization. The door needs a thicker film than the light layer the tung oil (thinned varnish) provides.
Lee
Re: I'll venture a guess
Lee Schierer McKean, PA
Since that is a sink cupboard door, I'm with Lee, some thing like drain cleaner or cleanser with bleach was on the fingers of someone closing the door. I also agree that Tung oil is a poor finish for a kitchen cabinet, particularly one close to a sink and a dishwasher.
Lee
Polymerized Tung Oil
Howard Acheson
Tung Oil or polymerized tung oil, in spite of the marketing hoola, is a poor choice for an area that will be frequently wet and/or may be getting other chemicals on its surface. Tung oil has little resistance to moisture and virtually no resistance to household chemicals. At the very least, a film finish like lacquer would be a better choice. Much better would have been a catalyzed lacquer or an oil based varnish. These last two are the most water and chemical resistant.
That said, I agree that some aggressive chemical has gotten onto the surface. It may also have be absorbed into the wood. I would think that you will have to completely remove all the finish and then decide how you want to proceed.
Re: Polymerized Tung Oil
les winter
First, I appreciate all the info.
I used this polymerized tung oil (Sutherland Welles) on an island which is made of edge-glued hard maple and cherry. It is the main food prep surface in my kitchen.
The finish has worn like iron. Yes, after I think 4 years' service, it could use a re-coat, but this is expected. While it may not wear as well as some other finishes, I have had very good luck with it.
But I have never exposed it to any really harsh chemicals. Maybe the cleaning lady did.
So I think I will dig out the icky stuff, recoat with the tung oil and then lay a protective layer of varnish over it.
If anyone has any further ideas, I would appreciate hearing them.
thanks all.
Les
Waterlox
David Yoho
If you're going to do that, perhaps kill two birds at once by applying some Waterlox (tung oil based varnish).
Marv
I'm a bit concerned about that bowl of soup setting on the floor.... :\
Marv
