OT - mouse won't budge
Howard In Toronto
I'm hoping somebody knows what to do.
My mouse has frozen. Disconnecting it, changing the batteries, using other mouses, restarting the computer............ You name it, I think I've done it and ain't nuttin working.
Can somebody here steer me towards a fix? I'd sure appreciate it.
Thank you.
Howard
Re: OT - mouse won't budge
del schisler
don't know how you can click on and read this?? Did you plug another mouse direct in to the green ps2 if so and didn't work i don't know how you can click and do some checking . Sound's like a repair shop is needed.
David Yoho
Howard, you didn't say what kind of mouse it is. Since you mentioned changing batteries, I'll assume it's a wireless mouse that plugs into a USB port. If so, have you tried it in other USB ports? Do you have a mouse that plugs into a PS2 port on the rear of the computer? You might try that too. I'll assume also that you might have tried a known working mouse from another computer on yours. If so and it didn't work it might be time to have someone look at it. Nothing is ringing a bell here at the moment. Usually if one type doesn't work (like a USB) another type (like a PS2) should.
Ken Krawford
Howard, have you installed any new programs or Windows updates lately? My corless mouse and keyboard stopped working after installing Vista SP2.
Dave Paine
Good advice from the other replies.
My way to tackle problems like these is to eliminate variables, starting with the most simple.
I am presuming the batteries mean you have a wireless mouse. You mentioned about replacing batteries. Were the replacements at full voltage. I have experienced "new" batteries which turned out worse than the ones I was replacing.
The wireless mouse connects to a small device plugged into a USB port. If the USB port is on a hub, this is another variable to eliminate. Try moving this to another USB port, especially one on the PC. My wife had a card reader which stopped working. It was plugged into a hub. I moved to a different USB port and it then worked.
You may need to plug in a wired mouse to confirm you can get some mouse to work, and as another reply stated, one which is working on another PC.
Another reply mentioned if you had any recent software updates or installations. You may not have seen certain program updates if your system has auto update activated. I fall else fails, you may have to restore the operating system to a point in time prior to the mouse stopping to work.
Good luck with finding the root cause.
Hal
I'm having similar problems with a laptop computer. But it's a USB problem, and not the mouse. The USB port is sending out intermittent signals based on the little light on top of the mouse. Guess it's shop-time for the laptop. (I've tried several wireless units and they do the same thing.)
Hal (on the York River in VA)
FredD
I have a Logitech wireless keyboard and mouse and when that happens it's either ,press the little button on the receiver for at least five seconds or the reset button on the back of the keyboard.
If you have a little free standing receiver like my , sometimes just getting it buried under some paper or to close to the keyboard will freeze the mouse until you move the receiver.
FredD
