trash can cyclone lid ??? *LINK*
del schisler
My set up is just like the picture with the elbow pointing the same way . Now when it get's 1/2 full the chip's go into my delta dust collector bag. Is this normal ?? I thought that when the can got say 3/4 or more the chips would go to the dust collector bag. Any idea's or about 1/2 full normal?? thanks i put a link so you could see the lid
http://www.woodcraft.com/catalog/productpage2.aspx
Re: trash can cyclone lid ??? *LINK*
Bill Howatt
I have a LV lid and had the same problem. Obviously it you can get a taller rather than shorter can it helps. When I upgraded my DC I put the lid/can in the line with the jointer and planer such that it is gated off when I'm using other tools.
Before the upgrade I made a large circle out of thin paneling that I placed in the can about 4-6" or so from the top. I removed it when using the jonter and planer. This kept the bulkier shavings out of the can.
Bill
Re: Thien it.  *LINK*
Chuck Lenz
J. Phil Thien's Projects
Dave Bair, Eaton Rapids, MI
I, too, have the LV lid. I reduce the amount of suck by opening an additional dust port to keep more chips in the garbage can.
Dave Paine
You are observing physics in play.
The air volume is being spun around within the garbage can at a high rate of speed, less speed than in the duct, but still fast.
The larger particles will only drop out of the air if the speed is reduced. This is why some other replies talk about additional openings to reduce the pressure.
This works to drop out the chips, but the reduction in suction pressure will be felt in the entire system and hence flow in the system.
A good cyclone design reduces the diameter in the cyclone to reduce the air speed and get the particles to drop out of the air without reduction in pressure.
I built a home made top, and although I used a 45 gallon garbage can, it just was not large enough. It did not take long to get to the point that the particles went though to the dust collector bags.
I no longer use my lid/garbage can. In addition to being not as effective as desired, it had a lot of pressure drop. Once I removed this from the system I noticed a big increase in suction at the tools, and so less dust at the tools.
Re: Presure drop???
Chuck Lenz
I think it depends on what type of system you have, a stationary ducted system, or a portable system. What I understand on a ducted system, depending on what CFM your DC is, your main trunk line is limited to size and length without sacrificeing too much CFM. The original poster never said what type of system he has, nor did you Dave. My system is portable, it's a Delta 50-760 1 1/2hp with a onboard 30 gal. side inlet seperator with a Thien baffle in it. I equate the seperator as if it's a main trunk of ductwork, and I usually only use about an 8 ft piece of flex hose with it to the machine that I want to collect dust from. The last time I used the DC I was surface planeing six 6ft long 2 x 10's down ti 1 1/4". I filled the seperator right up to the bottom of the baffle. I was very suprised and impressed. I guess if your running a portable system I wouldn't worry too much about alot of CFM loss happening with a seperator as long as you keep things sealed up, but if your running a ducted system you may want to reconsider and do some math, unless your running a monster CFM dust collector.
Re: Presure drop???
del schisler
to bad you couldn't resaw them down closer to size and save the wood . Rather than saw dusk . Just a thoght after the fact. I resaw all my wood to the closest size. May have a use for it later? Just my 2 pennies
Re: Thien it.
Walt Smith
+1 on the Thien baffle. They work really well. Not as well as a cyclone but they make a cartridge filter practical IMO. Some fine dust makes its way into the filter but virtually NO chips or larger particles. Mine is built into the dust collector funnel so i don't have to find a place for another container. And they work with 6" hoses.
