tripod table leg hardware
DizD
Just looked at a small tilt top table - maybe 20" tall with top 10" X 14" or so. The legs look to be about 5/8" thick and are joined to the column with what appears to be a brass fastner. It looks like there may have been a hole drilled into the leg and into the column and the brass piece was two tubes of brass to fit the holes with a small brass web. From the end the brass piece looks like a figure 8. Just curious if anyone has seen/used something like this. I don't remember ever seeing hardware like this.
Re: tripod table leg hardware
Re: tripod table leg hardware *LINK*
Bob Entwisle in NJ
Does it resemble this?
Bob in NJ
http://www.paxtonhardware.com/prodinfo.asp?number=4720&variation=
DizD
No. The hardware I was asking about is under the legs at the bottom of the column where you would sometimes find a spyder ( isn't that the name of the reinforcing plate used where the legs join the column?)
