Tool justification? Ridgid Spindle/Belt sander *LINK*
Okay - I have a request for a few items. It is a paying job - so I will be reasonably compensated for the work.
I don't have a oscillating spindle sander or a belt sander. This would make the job a lot easier - but I don't really NEED it to complete the work. I've seen the Ridgid spindle/belt sander and used the one they have over at the Folk School.
Obviously - I could use the money for Xmas presents.
Re: Tool justification? Ridgid Spindle/Belt sander *LINK*
del schisler
i have the same RIDGID Oscillating Edge/belt Spindle Sander in my shop. Depend's on what project i have used it many time's. I find it to be very good. Now a little advice On the locking nut that holds eather the belt sander or if you use it as a spindel . Be sure and leve the nut loose when you are done. If not the dam nut will get so tight that you will never get it loose. I had my first one get so tight i used a pipe wrench and still it wouldn't come off. I took it back and they gave me a new one. So leve it loose. good luck
Phil Joines
Don't own one but I have used one a bit. It seemed to me to be good for small pieces. The table is too small for anything sizable. I needed to be careful not to use too much pressure and stall it. The dust collection worked good with a shop vac. It tended to walk around on the bench but it wasn't secured in any way.
Chuck Lenz
( It is a paying job - so I will be reasonably compensated for the work. ) First of all that is never a given. In most woodworking projects I would say the majority of people are very rarely ever reasonably compensated. As far as justification to buy a tool, if it saves you time now and in future projects, thats allways been enough reason, if I can afford it.
Jesse Cloud
I have it. Its ok, but not great. I use the spindle, but the "belt sander" seems to be a joke. Don't count on the spindle being square to the table - it does need fiddling often. Dust control is surprisingly good.
Bottom line - its pretty good for that price range, next level of quality is several hundred $ more, so unless this is something you will be doing a lot of, its probably a good buy....
Good here
Hoa
I have been using mine as a hobbyist for the last 6 years.
If you plan to use the sander 8 hours a day, 5 days a week, look for something else.
If you're like me, using it a few hours each month, it's great for the money.
It's very versatile; changing from a spindle sander to a belt sander takes a minute.
It's noisy (but the shop vac or the dust collector is probably noisier), and dust collection is OK, not great.
It vibrates a bit due to its light weight. I clamp it to the workbench or a Workmate - problem solved.
If mine stops working tomorrow, I'll buy a replacement the next time I have a chance to HD.
David Yoho
JL, you're in a good position, having used this machine already, to know if it will meet your requirements now and going forward. Certainly the price is not going to break the bank either. I'd say if you think this tool will make your life easier and you're satisfied it will do the job for you, there's no reason not to get one.
Personally, I have two dedicated bench-top machines that serve those tasks better for me but it all comes down to the type of work we all do and the efficiency and quality we require from them. While the Rigid machine would have no place in my own shop, it obviously does for others. Go ahead - you know you want it - go buy it and get back to making sawdust man!
Re: Good here
Janice Manuel
And I'm on my second one. It took about 10 years of steady use to wear out the first one. For a light duty tool, I have no complaints.
As to the spindle not being square to the table, I have never checked mine. The edges I'm sanding...it's not that critical they be perfectly square anyway...
I use the spindle more than the belt, but it is so easy to change from one to the other. Simple machine...does the job.....
..Not a fan
Yonak
My opinion is that this is not much more than a toy. It's not solid or square. Mine burnt out in 6 months. The good thing is that it had a lifetime warranty, however I chose not to go through the hassle of replacing it, but got a better-built spindle sander, instead. The fault is partially mine, though. I should have known by looking at it it wasn't suitable for regular use. I was captivated by the oscillating belt.
Jon Weisenbach
I've had one for almost 10 years and while restricted by the small platen length on the belt it does a reasonable job for most smaller shop projects. As stated in another reply the next size up is quite a bit more money for the added size and features. All in all it's a fairly good tool and has very good dust collection!
Dave Paine
I have this machine. It can do the job. Another person mentioned about the nut potentially getting stuck. I have had to use pliers once, but it did come off.
I find it easy to burn the wood perhaps due to pressure, perhaps due to the belt.
I have purchased good quality Klingspor belts which helps.
With any belt I get a thump, thump as the belt joint passes.
I have found a large disk sander better for sanding outside curves. The spindle rolls do work for internal curves.
For edge sanding, I no longer use this tool, since I purchased a different sander which works better for edge sanding.
For the price, this unit is useful to have around.
If you were not budget constrained a dedicated spindle machine and a large (10 in +) disk sander would perform better.
Bob Entwisle in NJ
I have one and like it a lot. I've had it close to three years.
I got it on sale for about $150.
It has the lifetime warranty. I recall someone on WC a couple years ago, (maybe Jan, 2008?), reporting that HD sent him a replacement machine for a 7 year old machine that had stopped oscillating.
In my space constrained shop, it's handy to be able to stash it out of the way.
I've not had any problems with it.
As to the reports of problems with the brass spindle nut, I think you just have to treat it like a brass nut and not a steel nut.
As to alignment of the belt and spindle square to the table, there is an adjustment to square the front table to the belt, which I had to tweak a little when I first set it up.
I just now, took an engineers square to the spindle and it is square to the table and I've not touched any adjustments on this since the first set up almost three years ago.
Having a stationary sander (even a small one like this) has been very useful to me. There are a lot parts that are easier to 'take to the sander', rather than hold them down and take a sander to them, and of course the spindle is very useful for refining curved parts.
I'd buy another one if I ever wear this one out.
Bob in NJ
