Mystery Lights problem on Mazda Pickup questions?
I have a 99 Mazda Pickup Its a stretch cab with jump seats behind the main seat. Today I realised the dome light was on and I could not turn it off. Slammed all the doors and fiddled around with it and tried the switch on it and turned the key off. Finally took the bulbs out. Came back from an errand and found the white lites high on the back of the cab on. (perhaps they were on before and I did not notice). Can't remember them ever being on before, but maybe they were and I just could not tell. Not sure the dome light ever worked before either. Removed the exterior bulbs also.
So, any ideas why these lights would decide to go to work and refuse to quit? Any suggestions for a fix?
Re: Mystery Lights problem on Mazda Pickup questions?
Jesse Cloud
I have the same problem on my 99 Ford Ranger, made by Mazda. Came down to a faulty door sensor - cabinet light comes on because it thinks the door is open. Repair place estimated a couple hundred to fix it. I just took out the bulbs.
Might be worth a quick onceover to make sure there's no debris or anything in your door jambs that might interfere with the sensor.
Hope yours is something simpler!
Jason Roehl in Lafayette, IN
If the exterior cab light was on also, then it's quite possible you have your interior dimmer switch set one notch too high--set to the notch that turns on the interior lights along with the exterior cab light.
Jason
We have a winner!!! Jason and Wood Central....
come thru again.
It was the dimmer switch. I had fiddled with it and did not realize it turned the lights on. Thanks. I even read the book and it certainly was not clear. No indication I could find that the same switch operated the dash lights and the dome light and the lights on the back of the cab. Still can't find any reference to the lights on back of the cab in the book. Now that I know how to turn them on, they might be handy. I had asked at the station where I get it inspected and they did not know, but said they were not required for the inspection.
Thanks again.
Re: We have a winner!!! Jason and Wood Central....
Stuart Johnson
The same thing happens on a F-150. Last Monday we were on our way home and stopped for the night. Somehow I turned the dimmer switch and the lights were on when when went out for dinner. While I tried everything short of removing the bulbs my wife read the manual. One more thing I'll be reminded about for next 30 years.
This used to be standard operating procedure on American vehicles. I have no idea how it's done now.
AZ in Colorado Springs
My '00 Silverado has a thumbwheel in the dash that changes the brightness of all the dash lights -- speedometer/instrument cluster, a/c, heat, etc. If you turn it all the way to full, there is a detent and the overhead dome light comes on. There are separate push buttons for "dome light over ride" and switching on/off the cargo light for the truck bed (located over the rear window with the 'third brake light').
My '00 Silverado
Dave Bair, Eaton Rapids, MI
I, too, own an '00 Silverado. After a few hours of after-dark driving, the brightness-controlling "wheel" gets so hot that it can't be touched for more than a few seconds. I repeatedly complained to the dealer, to no avail. I guess it's okay since it hasn't caught fire in 11 years or even warped the plastic dash around the wheel.
