OT - Plumbing problem
Ralph Lipeles
I have a pin hole leak in the 3/4 cold water line. I usually fix this problem with a small piece of rubber clamped to the pipe with a small radiator hose clamp. However, this time, the pipe must be really weak and the leak got worse. I do not have time or inclination to replace the entire pipe now and was wondering about a patch solution. I see SharkBite fittings at Home Depot and Apollo fittings, at half the price, at Lowes. Looks like I can just remove a section of bad pipe and pop in a new section without the hassle of draining the system and soldering in a new section. Does my approach seem reasonable? Are the Lowes fittings just as good as the Home Depot fittings at much less money?
Thanks in advance for your help.
Ralph
Re: OT - Plumbing problem
I guessing you have copper pipe and are on well water. Some water literally dissolves the copper and I have seen systems where the pipe became so then you could crush it in your fingers like foil. If your pipes are thinning out that badly you are going to be forced to replace the whole system soon.
Locally Lowes and Home Depot carry Shark Bite or Gator Bite fittings. One at one store and one at the other. They appear very similar and are similarly priced. I have not seen the others you mention. I do know that they work very well on decent pipe. If your pipe is in as poor condition as you indicate, I am not sure they would work at all. If your pipe is more sound than I think, you might try a Dressler Couping. Its a fitting that is about three inches long. Cut the pipe, slip it on and side slip it over the other one and tighten the ends.
Nat Robison
I've used the fittings sold at Lowe's....think they were Gator Bite, don't recall seeing Apollo. I think they're a great solution, especially in areas where you have access to the pipe in case there's a problem, though I've never had a problem with them. I guess I'd be a bit leary about the 1/2 price fitting. I think a 3/4" union sold at Lowe's and HD went for about $7-$8.
Clint Searl
Clint Searl
I recently used the 1/2" single use ones from Lowes on a shower/tub body replacement. They're better than trying to cement PVC or sweat copper in tight quarters. The only lookout I found was the need to have some linear play in the line to fit them in.
Clint
PS...
I have not looked lately, but the apollo fittings I am familiar with from Lowes are for PEX pipe and have a crimp ring on them. If that is what you are talking about, they are cheaper than Gator or Shark Bites, but will not work on copper.
Paul Leuba
I have also had good luck with the Sharkbite fittings from Home Depot when used on good solid, clean pipe.
However, you are probably experiencing acid etch on the copper pipes from well water. If that is the case, then your entire copper pipe system may be compromised, particularly the horizontal pipe runs.
If the pipes are not too thin, then you could install an acid neutralizer to bring the water to a neutral PH and that would prevent further etching. However, if the pipes in the house are all very thin, then replacing them with CPVC is probably the best solution.
Paul in Hunt Valley, MD
Steve Schoene
Why not PEX if you have to replace most of system. Many fewer joints to make.
Clint Searl
Clint Searl
The connectors work work with PEX and PVC, also. PEX requires an insert that's included.
Clint
i'm A Woodworker, Not A Plumber....
Barry
