Letting wood "equilibrate" after cutting...
I typically joint and plane and rough cut most of the lumber for a project at one time. As an example, today I planed down a bunch of 10/4 maple for some corbels. I also resawed some to near 3/4" and planed it down to final thickness. I then rough cut the pieces to size.
Rather than do the finish cuts on the same day, I usually wait a day or two and go on to a different project on that day and sometimes the next.
Do ya'll let the lumber equilibrate after planing, jointing and cutting? I usually do it this way for air-dried and kiln-dried after having a piece or two turn into a nice banana shape.
Re: Letting wood "equilibrate" after cutting...
Absaloootly
In fact I go one step futher. I let it sit 'till the next day after face jointing. I'm working with a lot of air dried "character" cherry and maple, so I can get compression wood any time.
I mill my stock for a piece with every dimension an 1/8th big then let it sit a week. I recut before assembly.
Dale Lenz
No
Dale Lenz
All of my lumber has been in my shop for several months at least. So I don't see a need to, haven't had no problems. I've been using AD stock for nearly 30 years now. My shop is heated and A/C while I'm working in there, so the RH is normally in the "house" range.
another no approach
Bill Tindall
I only use KD lumber. The only time it moves after cutting or planing is if there is tension in the piece, for example improper drying, and that is very rare. When we sold lumber it would come off our truck, into a shop, and in two days it would be kitchen cabinets, or whatever.
I guess the main thing here is how different is the moisture content before and after you work it. In my case, very little, so equilibration is unnecessary.
Re: another no approach
Jesse Cloud
I was taught that if you are doing the joinery and the assembly the same day you mill, just go for it. If not, leave it 1/32 fat and do the final milling when you are ready for it. If I mill a set and leave it till the next weekend, I always get a piece or two that is no longer square, even with careful stickering and humidity control.
Doesn't matter whether the wood has been in the shop for a couple of years or not. Especially a problem when I resaw thick wood.
David Yoho
I generally use KD lumber but do work some air dried at times too. Because I purchase rough stock more these days, I've recently started creeping up on my finished dimensions. On my current headboard project I started with 5/4 cherry recently purchased, 4/4 and 8/4 curly maple that's been in my shop for well over a year, and jointed it in batches first. I then planed it all a little over in size and let it rest a few days. Another pass over the jointer and into the planer to final size and I'm ready for joinery and assembly.
What I've experienced by doing this is the wood does sometimes move a little and causes things to not be square. By not rushing to final size, I still have a chance to correct the problem. However, if you're making something that will get assembled quickly, it's alright to go straight to final dimension with your stock. Due to the nature of the time I have in the shop, sneaking up on the finished size works better than not for me.
JL, I am not an expert but have been woodworking for a long time. I often let my stock equilibrate simply because woodworking is a hobby for me and I work a few hours doing stock prep and then have to wait a few days for more time in the shop. There have been a few occasions when I found some pretty strange things when I returned.
What I am getting at is I can't think of any negative to letting it adjust other than you may waste some time. I think you would be about 90% safe going directly to final dimensions and assembly and even finishing, but there may be a few times when you wished you hadn't. I don't think letting the wood adjust for a few days causes any problems, it just gives the problems time to show up.
Jim Dillon
JL,
I allow my roughly jointed and planed stock to equilibrate for a few days depending on my schedule. I sticker the boards as well. Even if the rough boards have been in my non-AC, but heated, shop for a long time, I still try to take the time to do this. This approach works just fine as I can usually fit in other woodworking or non-woodworking tasks during that time. But then again, I am just a hobbyist.
Jim
Clint Searl
Wood never sleeps
Clint Searl
