REAL MILK PAINT
Polishing Stainless appliances OT
My son bought a Stainless steel fridge at the local Sears scratch and dent. It has a pretty severe scratch on one of the handles. He could buy a replacement handle, but could it be polished and reduce the impact? I'm thinking of filing it down with diamond hones. Is there a finish over the stainless? ie lacquer or something. Any suggestions.
Re: Polishing Stainless appliances OT
Tony - Memphis
We just bought a Whirlpool fridge in stainless. (I hate it but my wife loves the stainless look - guess who does the polishing?) None of our stianless appliances appear to have any finish on the stainless. I use one of those polishes in a plastic container with the pull out towels. I forge tthe brand but I did a lot of research because ours shows every single little mark. This polish helps. It leaves streaks that can only be seen in certain light but it gets rid of the marks (fingers, water, etc.). So, you may be able to get rid of the scratch by finding the right level of abraisive to match the pattern. I'd try it and see. If mine gets scratched, I'll try it.
Tony
John Veerkamp
Barry,
Typically no finish over SS. You can find all kinds of "home remedies" for cleaning and polishing SS. If you decide to hone, be aware that the surface on SS is basically a pattern of fins scratches. Experiment on a unobtrusive place like a bottom side with various grit abrasives to achieve the desired result. It will not be a straight pattern either. Probably something like 300 grit sandpaper or maybe coarse rottenstone. Too fine and it sticks out like a sore thumb.
Barry,
Stainless is usually "finished" with a wire brush rather than abrasives; sheet material is run under a drum unit so the scratch pattern is uniform in a single direction. IIRC, there are several finish brush sizes 00, 0, 1, 2 and 3.
Your repair will have to be in two stages. Remove the handle from the appliance. With your fine file, stroke carefully in the "grain" direction to take off the slight burr on the edges; won't take much. Then with a very fine steel wire wheel in a drill, gently re-brush the item from one end to the other in the area of the old scratch. Don't try to spot-treat the damaged area as it will stand out from the rest of the surface.
My first introduction to "polishing" stainless
About a million years ago (1972), I worked as a custodian in a school district. One of the senior custodians introduced me to how to polish the stainless steel tops of the water fountains in the high school to which I was assigned: you lightly oiled a cleaning rag with mop oil (a light oil that we used on the mops - they pick up dust better), and ran it over the fountain. It wasn't durable, and had to be done daily. All it did, really, was to put a thin film of evenly smeared oil on the metal, but it sure did improve the appearance.
It was, at the time, a bit of a shock. I just didn't think of that as polishing, exactly.
Jennifer Indy.USA
Barry check to make sure it's really stainless. If a magnet sticks, it's not stainless. My Fridge looks like stainless but It is just brushed steel. The dishwasher and stove look exactly the same and they're stainless. Not sure if the two would be dealt with differently as far as what you're looking to do. I think they make the fridges brushed steel so you can still hang kitchen magnets on them. Sounds crazy but that's what I was told. People got them home and then couldn't hang their kids pictures on the fridge and were irritated so they started making them out of the brushed steel. Seriously.
Jen
Myths and truths about stainless
Lee Schierer McKean, PA
First of all stainless has no coating. It is resistant to rust by nature of its chemical composition. Stainless can and will rust if iron is left exposed on the surface. You can clean the iron off through passivation using nitric acid.
Brushing stainless with a steel wire brush will contaminate the surface with free iron. Do not do this.
To clean stainless, spray with Windex or any glass cleaner and wipe it down with a wadded up newspaper until dry and streak free. I did this for four years at the Naval Academy and passed every inspection.
Stainless and chlorine do not play well together
Some types of stainless are magnetic. The 400 series stainless is magnetic. 200 series may also be magnetic. The 300 series is not magnetic except edges that have been machined.
Some manufacturers are using a cladding material (veneer) of stainless over steel.
Where I used to work they would satin polish stainless with 2220 grit and 320 grit sand paper. It takes a lot of skill to get the polish completely even.
lee
You're right
Neal in San Jose
To say I was surprised when the old fridge magnets stuck would be an understatement. I haven't checked but I'm guessing the front of my SS fridge is brushed steel with some sort of coating to resist rust. So tread lightly until you figure out exactly what you have.
FYI
DaleLenz
Your statement that stainless is not maganetic(sp) does not Always hold true.
http://www.physlink.com/education/askexperts/ae546.cfm
The link box is not showing at the time of this posting
Jim in Burlington Ont.
Re: Myths and truths about stainless
Jim in River Oaks, Ont.
Hi Lee,
Good catch on the magnetic properties of some SS.
As you have pointed out there are many forms of SS and processes of application depending on need. It is very common to laminate SS as a skin over other structural metals or materials (cost, weight etc). It is also not perfectly corrosion proof, nothing really is, it is only delayed.
Take care,
Jim
