Authoritive word on hide glue working time
Bill Tindall
One of the great things about IWF is the opportunity to meet useful people at companies. Like I met the product design person at Freud, for example, and a chemist from Franklin glue company. I recently emailed him about hide glue working times. I reported earlier on their other wood glues.
Franklin defines two working times:
Open assembly time- the nominal maximum time one can leave the glue exposed to air before closing the joint. Longer time leads to a dry surface that will not bond properly.
Closed assembly time- the nominal maximum time one can diddle with the joint after it is closed up . Longer time and the joint will lock up or the bond will be degraded by moving the parts.
Liquid hide glue has the longest of these two times of the glues they sell, somewhat better than "Extend". For liquid hide glue the times are 10 and 20 min for a 30 min total working time. These times will be less at higher temperature and lower humidity or lower moisture content of the wood.
