Assy ??
Ray - Middletown, IN
The blue and green parts are already assembled and ready for the copper part. I'm not sure that glue will be enough (kid use) and I don't want screws or plugs showing. General consensus?
TIA
Ray
Assy ??
TIA
Ray
Couple questions first...
doug f, san clemente, ca
I think we need a bit more information.
First, what is it? Table legs, pull up bar, clothes hanger?
Second, where's the force coming from: top, sides?
Is it an optical illusion or does the downward piece (a leg) very subtly cant outward? If so, that's one complicated joint.
Doug
Re: Assy ??
Brint in Richmond, VA
I'm not an expert, but it seems to me that - so long as the joint is well-glued and well-clamped - the green member will fail at the notches before the copper member fails at the glue joint.
Tough one, Ray
That joint is mostly endgrain, except for two small cross-grain squares on the green piece. It would be hard for me to place a lot of trust in that glue line. It seems like any strain in any direction could defeat it. If it were me, I might try putting some kind of gusset(s) in those inside corners -- at least in the horizontal plane.
It's a bench top
that will consist of 3/4" slats for the top. I'm afraid of kids sliding off and puting side pressure against the outside slats.
The legs are slanted inward by 11 degrees, and yes the joint is a challenge for my newbee.
Ray
Re: Assy ??
There will be the copper pieces all the way across making it a solid piece of wood when done. I'm afraid of the outside pieces coming loose down the road.
Ray
Re: Assy ??
You say you don't want screws/plugs showing. Does something underneath count as showing? If not, you might consider a screw at 45 degrees or so coming up from under the copper piece into the green piece.
Re: Tough one, Ray
Don at Central Illinois
What about glue with small wooden dowels?
Re: Assy ??
steve mackay
Blind pins or brackets on the inside ?
How about this
Centered on the bottom inside and angling up into the slat. Follow the black line.
Maybe that would help pull the slat into the corner also.
Still guessing
Thanks
Ray
Great minds
Just had that thought and posted it.
Thanks
Ray
Re: Assy ??
Thanks Steve, more ideas to play with.
Ray
A dovetail would have been suitable
Bill Tindall
Updated pic
Here is a little more of the end.
Ray
Would have been a good idea, but
pieces have already been cut, grrr.
Ray
looks good to me
Bill Tindall
If you get good joints that should do just fine. There is oddlins of long grain glue surface.
Re: Assy ??
FredD
Assuming all of the copper tone pieces that form the top are notched like the one shown, then you have weaken the pieces by half with the notch and at the inside corner of the notch , don't be surprised if the wood fails at that point
FredD
OT - Sketchup?
Terry Alexander
Ray,
Just curious if your drawing was originated from Sketchup. If so (I'm just now starting)....how long did it take you to do it.
Again......more curiosity than anything.
Terry Alexander in West Texas
OT - Sketchup? -- Nope
A very old version of Solid Edge. Didn't take very long, maybe an hour, but then I'm very rusty. I don't use it enough to stay proficient any more. I have to stop and think ,a I'm loath to do that anymore.
Ray
I'm aware of that and have a plan..
