Waterbased Finish & Spray Guns
Thomas Norton
Is it just me or is it really that much harder to clean up a spray gun after using a waterbased product? I sprayed a waterbased primer yesterday,Zinseer 123, and after much srubbing and wiping I got it clean. It seems so much easier to use solvent base.
Re: Waterbased Finish & Spray Guns
Being an acrylic coating, if you let it sit in the gun, you're asking for trouble as it will dry in spots and takes work (you did) or some nasty ("Goof-Off" etm) solvent to remove the dry patches. Don't know what you're priming, but I use the stuff and usually roll it on as I use it for stain-kill a/o sealing walls. Don't think I'd use it on metal as there are much better products.
David Yoho
On the occasions I've sprayed Crystalac water based lacquer, I didn't have any problem cleaning out the gun. It was a total breeze to clean and took much less time than when I've use solvent based coatings.
Perhaps that particular product you were using is more difficult to clean. My own experience with what I've used in the past was different.
