We value your privacy.
I am looking for advice on how to make a transition from Beadboard Wainscotting to tile. The backwall of my Bathroom will have Beadboard Wainscotting going 4ft up the wall and it will intersect with the Subway tile I am using in the tub/shower. I didn't want to just butt the 2 together so I am looking for some ideas on what to put between them as a transition.. Maybe a piece of fluted moulding that runs from floor to Cap Rail and creates a visual barrier between the 2 areas. Any and all thoughts would be greately appreciated. For dimension the tile is 3 feet wide and the Wainscot will be 6ft wide.
The transition I am referring to is a vertical transition, Beadboard on the right, tile on the left, what do I use to sepeate them.. Beadboard runs down the wall unitl it intersects the tub and Shower then tub and shower has subway tile.
...that you would want to use something fairly thin and narrow. Maybe a piece of scribe moulding or a piece of quarter-round.
Another option, especially if the wainscot is painted, is to simply grout the transition, neatly of course, or caulk it (with paintable caulk, NOT silicone, then paint the caulk so it doesn't discolor).
If the wainscot is stained/varnished/otherwise naturally finished, then maybe an aluminum cap for the tile (has a lip that goes under the tile, then gets grout between it and the tile) would work, with the wainscot simply butted up to that (must be cut very accurately), but even then, I would lean towards some sort of very thin and narrow scribe moulding.
I had to turn the photo to provide a visual idea, but find a border tile compatable with your subway tile and highlight the transition rather than blend it in. This example may not fit your taste but there a hundreds of border tiles made for subway tile.
Are the two surfaces level to each other, or does one come out from the wall more? One of the traditional solutions to this kind of problem is never to have two such surfaces at the same plane, so that one finish can die into the other, or be covered with a molding that fits into the corner made by the meeting of thicker and thinner finishes. It gets more awkward when they're at the same plane.
Also: how are you terminating the cap rail if they're at the same plane?
It's not clear to me whether you've completed tiling or wainscoting, or if you're asking ahead of time. If you haven't done it, you might consider building out the wall where the tile will go just a bit, so that it is distinctly thicker than the wainscoting, enough so for the cap rail to die into it without sticking out. You would then use a cavetto (cove) molding in the corner, small enough in section to die under the cap rail, but large enough to cover the gap.
If they are at the same plane, you might consider something bold rather than discreet - a molding that runs past the cap rail, all the way to the top of the tile, and thick enough for the cap rail to die into.
By the way: "die into" may not be common parlance everywhere. By that I mean able to be cut off at 90 degrees and not stick out beyond the surface it's abutting.
You do need a little gap between wainscot and tile, to allow for expansion; I would not scribe it tight to the tile. Fill this with a flexible caulk, if possible; ideally, a molding would cover this (caulk is generally not very attractive, even when done well).
Use a wood species that will not rot, or a wood substitute - you may ask, "How does he know to mention that?" Um, bitter experience. This is one of a very few places where I think the modern foamy plastic fake wood moldings can be a good thing.
Incidentally, if the two surfaces are/must be at the same plane and you decide against a "thick" vertical molding, the traditional method of terminating cap rail and other moldings that stick out beyond a surface is to cut the end at 45 degrees where it begins to stick out. This is far more graceful than just being chopped off, but far less graceful than a molding that dies into the adjacent surface.
One of the variables here, which you haven't really mentioned or described, is "What is the rest of the room like?" If you need a transitional element, it should tie in with the rest of the detailing in the room. Typical detailing elements would include base moldings, door and window trim, crowns, chair rail, etc. However you decide to transition the tile to the paneling, I'd consider how the detail meshes with the overall design intent.
The major design element is the beadboard going around the room. Whatever I find to create that divider may drive other design elements, otherwise it will be pretty standard stuff..
