OT - I don't know anything about modern TVs
My existing color TV is over 20 years old.
With all the "deals" that are supposed to be coming soon, I thought I would ask ya'll what you thought.
We want a new TV. Our house is NOT large - therefore we are thinking about a smaller flat screen. Our existing TV is about 26" or so - and that is the size we would prefer (possibly a little larger).
From what I have seen, I guess that means we would have to get something with 1080 pixels and LCD. We are not great TV watchers. We have no cable and get no reception. We do enjoy movies and either rent or buy DVDs.
So - what brands are reasonable and what brands should I stay away from?
Re: OT - I don't know anything about modern TVs
wilbur
One thing to be aware of is that if your old TV is 26", it has a screen size in a 4:3 ratio. HDTVs have a screen size that is 16:9, which is a rectangle that is more stretched out than your current TV. A 26" 16:9 HDTV will give you a screen that is considerably shorter than your current screen. To maintain the same vertical height, you should be looking at a 32" HDTV.
In that size LCD is your only option. If you want to save some money, you can get by with 720 and skip 1080 unless you either sit really close to your TV, as in sitting 4 feet away, or you have incredible visual acuity.
On the other hand, the price difference between a 720p and a 1080p HDTV in this size range tends to be only just about $100, so if your new TV lasts you half as long as your old one, that works out to be an additional $1 a month.
I'd stick with the major brands (Sony, LG, Samsung, etc.) and stay away from house brands, like Vizio, Dynex, and so on. Beyond that, use your eyes to figure out which picture you like the best.
Howard Norman
I agree with Wilbur, especially with the fact that to have the same picture height you need to be considering a 32" TV. I don't know where you live but if you have a Costco nearby I consider them to be a decent source for TV's. You may want to consider a 40" TV also. It is amazing how people seem to realize how much nicer a larger TV is after they purchase one.
Dave Paine
As another reply stated, the TV world has changed and so 16:9 ratio is now the normal aspect ratio.
As you shop around, consider the power consumption. LCD and Plasma TV's consume more power than you may appreciate. You state you do not watch often, but the wattage could exceed the old TV.
Some companies, such as Vizeo, claim their power saving. Plasma used to consume more than LCD/LED.
I have a 52in Sony LCD and was surprised at its 300 Watt consumption at maximum brightness.
You asked a very broad question, and no easy single answer.
Today's TV's are expected to be integrated into Home Theatre and the Internet.
My Sony has ethernet connection, but it needs to be connected to a router. Latest models like include the wireless connection.
My Sony also has a useable PC connection. I used this initially for streaming Netflix movies. Now I have the PC connected to a wireless Bridge and so can stream movies and TV direct from Netflix.
You mentioned not having good reception, if you also do not have broadband connection then your viewing choices will be limited to the DVD's you rent.
These days 1080p is considered the normal pixel depth for DVD's, although in order to enjoy this feature, your DVD player needs to support.the pixel depth.
True 1080p is available only with Blu-ray DVD players. Other players may "scale" to this pixel depth, but they are converting lower resolution.
I would get the largest screen you can afford. As my eyes age, I appreciate larger screens more every year.
Re: OT - I don't know anything about modern TVs *LINK*
mdclor
JL,
I have found CNET to be a good source of impartial information. Below is a link to television selection info.
HTH,
Merle
CNET TV Buying Guide
Joseph Mulherin, Sr
JL, almost all stores are having sales on the new TVs at very reasonable and desirable prices....like at Target, Best Buy, Costco, etc. I recently bought a Sharp 42" from Dell and put it on my acct. Original cost was stated at $1,089, and I got it for $524 + sales tax in Calif....totaling $622.34 delivered. Set it up in about 20 minutes and adjusted the brightness etc to my own liking and we also have the USB facility for the computer and movies if we want.
Moses Yoder
Re:One suggestion
Moses Yoder
The only suggestion I wanted to make was rent Netflix. You can organize the list of what you want to see on-line and never have to go to a video store again.
John McGaw
As others have said, 32" is probably what you want to replace an old 26". The recent Consumer Reports rates flatscreen reliability (high to low) as Panasonic, Sanyo, Sylvania, Sony, JVC, Visio, Sharp and down from there in the LCD category. Among plasma sets Panasonic seems the clear winner. In the performance area they rate them in LG, Panasonic, Samsung, and Sony as tops in LCD and Panasonic as tops in plasma. For LCD sets, buying one with LED backlighting will probably gain you a bit of energy efficiency. Plasmas consume more power although probably not as much as your old 26" CRT.
I should note that CR doesn't ever get down to any sets smaller than 37" but it seems reasonable that quality might be similar among the brands' smaller sets.
Jerry Nicholson
I have had good luck with Panasonic and Sharp LCDs. I too would consider 32 inch to be the minimum.
Jerry
You'll also need an antenna *LINK*
Grant in Iowa
JL,
In addition to your new television, you will also need an antenna designed to capture the DTV signals and send them to your new TV in order to gain from all of the benefits of the new technology.
There are units ranging from small shelf top antennas to large roof top units. They vary widely in cost and signal capturing capabilities.
You may get some reception by connecting to your existing antenna, if you have one, so maybe bring home the TV first to try it out.
The FCC runs a web site dedicated to the subject that you may find useful. You can enter your zip code to get an idea of what stations you are missing now that you may be able to watch once you upgrade.
FWIW,
Grant in Iowa
FCC
Re:One suggestion
Scott Greaves in Blackfoot ID
I agree with Moses, and would add that streaming from Netflix over the Internet is even better! While my Wife was recuperating from her recent surgery she found she enjoyed watching old movies streamed from Netflix. She would just browse through what was available and stream it right then. Compared to the streaming from Netflix, receiving the occasional disk in the mail is almost anticlimactic!
Scott.
Are you sure?
Tony - Memphis
I am using my good old fashioned antennas that were built long before digital and I get excellent reception. I just have them in my attic. I have two split between a few tv's and dvd recorders. Works great.
We replaced our old 26" set a couple of years ago. I did a lot of research and we visited Sears to see what looked best to our eyes. Then I found a real good deal on a 37" Sharp Aquos. We have been extremely happy with the tv. The picture quality is amazing compared to our old set with an analog signal. Can't remember the spec's but it was not top of the line. I read that the higher pixel count is really much benefit unless you are up close. Anyway, I think you'll be pleased with whatever you get compared to the old stuff. And, you won't need a box to hook the antenna into. We bought a DVD recorder with it's own tuner, so we can record independently. Nice setup. The recording was more important to me as I rarely sit in front of the tv. I record what I want to watch and watch it while I excercise.
Tony
Tony
NO signal in my area.
None. I have mountains on all sides. To get TV signals, you either go Dish or get cable (or Internet).
The only time we watch any TV is at the gym.
Folklore and sales hype
Tim Greif - West of Chicago
There is nothing magical about hd digital signals other than they are typically weaker than their old VHF channel counterparts. It's been proven numerous times that rabbit ears are quite suitable for DTV reception. i use the same attic mounted antenna that I've had for 20 years and get all HD local signals just fine. Most stations broadcast their HD signals in the old UHF frequency range (channel 14 and up on the old system) because that was where the most frequencies were available prior to the shutoff of the old analog signals. Now that everyone has converted to HD, stations may elect to go back to the VHF range (old channels 2-13) at some point in the future. Although I don't see why they'd want to.
Most of this "you need a special HD antenna" comes from the techies trying to sell you a new gizmo, kinda like the monster cable hype of years past. I'm betting your old antenna will work just fine. If you get pixellation, you probably need a better UHF antenna because the signals are now a bit weaker than they used to be.
Re: NO signal in my area.
Alan S
Since you get no reception in your area and have no interest in cable, why bother with a TV? You can watch DVD movies on a computer screen. Just get a big monitor or a projector. If you later change your mind, you can always add a tuner to your computer. I don't know how monitors compare with TVs in price, but they could be equivalent for you, so it's worth checking both.
Re: Folklore and sales hype
Tom MacGregor
Totally true! There is no such thing as a digital or HD antenna. I replaced my 20 year old outdoor rooftop antenna because they do degrade over the years exposed to the weather. I replaced it with the exact same model still available and on sale at Radio Shack. It can't pull in a signal that isn't there to begin with, but it pulls in the new signals just as well as it pulled in the old ones. BTW I also have a signal booster (1/2 on the antenna, 1/2 in the house w/three conductor antenna wire). $60 from the Shack - big improvement.
