Dehumidifier kiln dried lumber
John in IN
I recently purchased about 500 bf of walnut and cherry that was dried using a dehumidifier kiln. Will this wood work like air dried lumber? Can it be steam bent?
John in IN
Re: Dehumidifier kiln dried lumber
Sgian Dubh
No, the wood won't work the same as air dried wood. It will work much the same as other examples of the same species that are kiln dried. There are differences between conventional medium/high temperature kilns and dehumidification kilns, but without going into a quite involved discussion of the differences in the modes of operation which would really take up too much space here, essentially the end product is much the same.
Kiln dried wood can be steam bent, but generally wood kiln dried to something like 7% or 10% MC won't bend as easily or as successfully as wood that is either green or air dried-- air dried to about 20% MC is generally considered the best compromise choice. There is a hysteresis effect with wood kilned to a low MC where the stiffness it develops due to the drying never quite relinquishes itself even after subsequent rewetting to a higher MC. Slainte.
try it
Bill Tindall
A lot of KD wood is subsequently successfully bent. I bought some chairs that have a substantial bend in the back and the splats from a shop that only uses KD lumber for bending.
I suppose the issue is cell collapse. Somewhere below 30% moisture content the wood cells begin to collapse and the wood shrinks. On the other hand the cells collapse when the lumber is air dried below 30%.
Re: try it
Sgian Dubh
Bill, I can't really describe any of the bends in those chairs as tight, severe, or substantial. Slight or gentle seems to fit the description, and I agree that even kiln dried wood should bend quite reliably and easily for those chairs. Somewhat more difficult are bends like those in the image below, but even these aren't overly aggressive. Slainte.
Not to argue with any of the experts, but...
I have steam bent air-dried lumber many times. I've gotten reasonable results. I've even bent dehumidifier dried lumber. This is NOT kiln dried lumber.
The kilning operations heat the temperature of the wood up to quite a high temperature. This sets the lignin in the wood. Drying with a dehumidifier or even a solar kiln isn't quite the same. The walnut in the picture below is from a piece of solar kilned lumber. It was dried to ~10%. I steamed it (and the others were actually used in the project) for about 1 1/4 hours before bending.
I would say that it bent quite well.
I've air-dried and dehumidified both walnut and cherry. If you're going to be bending, I think you'll find the open pored woods, oaks, ash, walnut, easier. Even overcooking in the steambox didn't help air-dried cherry all that much. I decided to leave bent cherry and maple to the factories with their bending machines.
It's all about temperature
Lee Grindinger
First, it's good to see my old friend Sgian here!
As to your question..., it's all about temperature. Wood looses elasticity and strength as it's heated. Early dehumidification kilns operated at quite low temperatures, mine ran at 110f on the average, 120f max. This did not hurt the elasticity of the wood nor did it relieve stresses that could have developed from over-fast drying so it was important that time was taken for certain woods.
I have not kept up but I'm guessing newer DH drying allows for higher temps. Higher temps are desirable in drying because water migrates through the cell walls of wood quicker at higher temps, it literally screams at temps over 200 but this affects the tissue so badly that even the most rushed conventional kiln schedules limit temps to 180 or so.
So, the short answer is this; If the wood never saw temps over 120 and if the drying was done slowly enough (determined by species and the speed at which water migrates out of cell walls) it will work and behave like air dried lumber.
I ran 2 DH kilns for years, they were fairly early versions and I'll be happy to answer any questions you may have. However, the best advice is to try bending the wood, that will be your definitive answer.
Lee
John in IN
Thanks to all respondents. I've been taught that kiln dried wood "sets" the lignin and therefore can't be used in steam bending, so I suspected that dehumidified dried wood may behave like air dried. I guess as Lee said, it would depend upon the temp at which it was dried. I do plan on trying some bends, but thought I would ask and see what I could expect. Thanks again.
