We value your privacy.
I have read that this stuff is "transparent", but in the can looks like plumber's putty. If it in fact dries transparent, can I use it with no tinting?
If I have to tint it, any reason I can't use a couple drops of liquid TransTint dye? Transtint is not listed on the can as an option, but that usually doesn't mean much.
But I alway tinted mine with Ronan(SP?) tint, purchase from Jeff Dewitt. The tint in the cans, Ronan dries up in the can over time, several years now, real PITA. I've looked at Trans-Tint, does not say you can mix with oil base, which is what Behlan is. If you try Trans-Tint, please let me know how it works out. Would love to fine a different tint, maybe in tubes, gotta get away from the cans.
That sounds like it may be like Sherwin-Williams Natural oil base filler.
I have always used that , whip it into a heavy cream consistency and if I want a color , I tint it with the same oil based stain I am using on that project.
Behlen's and Sherwin Williams are quite a bit different. The Behlen uses a number of filler materials, they appear by the CAS numbers of the materials appear to be chalk, plaster of paris or gypsum, talc, and chrystalline silica. Some of these will be more translucent in oil than others. The talc seems to have the largest proportion.
Sherwin Williams uses a very high percentage of chrystalline silica or quartz as the filler. This seems to shrik less, and to become more translucent in the pores when it has dried, though tinting is often a good plan anyway. The problem with the SW is that it is sold only in gallons, and you won't find it typically at the many retail oriented S-W stores.
"The problem with the SW is that it is sold only in gallons, and you won't find it typically at the many retail oriented S-W stores. "
That is not a problem for me Steve, but this is.......the last gallon I bought and it was the first one from a S-W store in Junction City , KS was , the woman manger did not know what it was and was sure I only needed wood putty.
After I assured her I knew what I wanted and apparently she didn't she decided in a huff to call the main store in Manhattan , KS which was the warehouse for the State and they said her inventory showed one Gallon in her store and gave her the product number.
You would laugh if you could see the condition of the can which I bought , it looked like it was stock from a dented can store which didn't make the grade.
Every time I go to our local SW store they don't know what I'm talking about. If you think of it get me the title and stock number off the can and I might order me a gallon of the filler, not putty!
Every time I go to the store they have new personnel. Now I just proceed to their back room and find what I need, usually to discover it has yet again been reformulated. I have moved to General Finishes products. They still use mineral pigments in their pigment stains, and the most light fast premetalized dyes for the dye stains. They don't reformulate products as much.
It is not clear to me what sort of look one wants to achieve by using a "transparent filler". Filler is particles. The usual goal is to use these particles to fill up the pores and accentuate them, by making them dark. It seems that this goal would be best achieved by filling up the pores with colored particles, ie pigment, such as will be found in old timey pigment stain or Japan pigment colors.
I typically fill with a burnt umber colored filler. I just add a dab of burnt umber Japan pigment, or burnt umber stain to the filler,
Pigment powders will tint just about anything as they dissolve in most any solvent. They work beautifully with shellac and lacquer.
And the real beauty is that you can get them "dirt" cheap. There's a big market for pigment powders among people who make their own makeup. Just google 'pigment powder.'
I've been using Crystalac filler for years to do filled-pore finishes. Very easy to both apply and tint. Sands well tints with Trans-Tint dye, although doesn't really need tinting if you level, apply an application of oil or thin shellac that penetrates, and then top coat. Gives a piano finish on walnut, oak or ash.
Let me take a shot at it Bill.
Fillers are used to achieve a level ,flat appearing surface to the wood especially Ring Porous woods like Oak and Semi Ring Porous like Ash without the ups and down in the grain , so a finish , particular one with any gloss will appear uniform .
Your thinking about using fillers to color wood ,would be more along the lines of "antiquing" rather then filling.
Woods with open grain and a lovely color in their natural state like Walnut and Mahogany, need filling at least on the horizontal surfaces without detracting from the woods color, hence the Natural or Transparent filler is the right choice.
I find that home grown beer. or stains or attempts at nearly anything that is mass produced by large paint and finish companies staffed with R@D Coatings Chemists is dubious at best.
