Tabletop finish
Tabletop finish
Kneale Brownson
Tabletop finish
Kneale Brownson
The finish on this Finn Juhl-designed table by Baker Furniture, Inc., of Holland, MI, from the early 1950s has been ignored until now, and I'd like to bring it back to like-new. I've followed Baker advice to use a mild wood cleaner (Murphy's Oil Soap) and wax (Briwax's Teak), but I think the original laquer coating is broken down. Can I sand it lightly and relaquer? Can I do that with a brush?
This closeup of worn finish on the edge MAY give an idea of the missing finish:
Re: Tabletop finish
Dale Lenz
My intial thoughts are...
Dale Lenz
Wash top down a few times with warm soap and water, rinse, let dry.
Lightly scrub with paint thinner.
Run some 220 grit sandpaper over the top.
Wash coat surface with Seal Coat, shellac.
Spray lacquer.
Rub out lacquer after 3+ days.
Re: Tabletop finish
Re: Tabletop finish
FredD
If you have waxed the edge and that is the only area to retouch, I would clean off the wax with paint thinner and using a small sponge dipped in Lacquer thinner , made one pass only along the edge , let dry and do it as many times as it is necessary to remalgamate the finish.
Baker Furniture is really nice Furniture , head and shoulders above it's competition.
Re: Tabletop finish
Clint Searl
Do not sand!!!
Clint Searl
I think anything short of stripping and refinishing is a waste of time and will leave the piece schlocky looking. I would start by completely stripping with either a MEC based or orange stripper, followed by a heavy washdown with naptha then acetone. Then a rubdown with a maroon scotchbrite and a final wash with acetone. I would finish with a semi gloss solvent lacquer, rubbed out with 0000 steel wool and Butcher's wax. If you don't have spray equipment, I would suggest a thinned oil poly wiped on in multiple coats and rubbed out as per the lacquer.
Clint
Re: Tabletop finish
Jesper, Denmark
Re: Tabletop finish
Jesper, Denmark
The Finn Juhl table is probably made from teak - venneered top - and was most likely finished with Danish oil originally. I think it would be a shame to finish it with a film coating, so no laqueer or varnish.
Hopefully, the veneer is not as thin as you would see it today, so a very light sanding and some steel wool followed by a copuple of coats of Danish oil would bring it back to the original matte finish.
Re: Tabletop finish
Kneale Brownson
Re: Tabletop finish
Kneale Brownson
It is teak, Jesper, over a walnut substrate. Baker's website says it would have been laquered. In the right light, I can see a bit of "crazing" of a film finish, and it's apparent where the film was worn off on some edges.
Re: Tabletop finish
"Danish Oil"
Bill Tindall
Back when this "oiled" look was popular Sherwin Williams sold a conversion varnish called Kemvar C. (They may still do) I suspect other manufacturers had similar products. I finished many "oiled" walnut pieces with it. I was a close to the wood finish, and dull, and from any sort of distance it looked like an "oil" finish. However, it was durable. Stuff finished with Kemvar C could be washed with detergent and water. Great for a table finish.
I wonder if any commercial furniture was really oiled. I suspect most if not all has some sort of oil look finish that was quicker to apply and cure.
Re: Tabletop finish
Clint Searl
Re: "Danish Oil"
Clint Searl
An "oiled" appearing finish is easily duplicated with a low sheen NC lacquer by holding back the build and rubbing out with dry 0000 steel wool or a maroon pad. It's more quicky done and more durable than any drying oil finish.
Clint
Re: Tabletop finish
Re: "Danish Oil"
Steve Schoene
And, to confuse the buyer, many such sellers of Danish modern stocked the retail stores with "teak oil" for preserving the finish. Sometimes an oil/varnish mix, it was often mineral oil with a few drops of colorant. Same stuff different tint--rosewood oil, etc.
Re: Tabletop finish
Lacquer vs oil
I agree, Clint, as far as the sheen and relative durability go, but oils and oil-based varnishes saturate the color of the wood in a way that lacquers can't. Though it seems counterintuitive, I know many craftsmen who apply a coat of oil first and then lacquer over it when it has dried thoroughly, for the best of both worlds.
Re: Tabletop finish
Clint Searl
Re: Lacquer vs oil
Clint Searl
Ellis, the NC imparts a soft amber tone, a la oil, or a dye stain can be added for a stronger effect. I've also done an oil pigmented stain under solvent lacquer for a pleasing effect (at least to my eye).
Clint
Re: Tabletop finish
Agreed
Bill Tindall
I always put an oil based pigment stain on walnut. If this step is followed up with a thin coat of delustered, or rubbed, lacquer or conversion varnish the result looks just like commercial "oiled" furniture. Real oil furniture look dead after a few months, in my opinion.
