Bandsaw blade vibrrration
Yonak
I'm getting this bothersome blade chatter which causes me to not be able to follow the cutting line so well, as well as extra sanding. I notice it when I'm cutting 1-3/4" ash wood, but not thinner or softer woods. It seems to be much more noticeable when the wood grain is more perpendicular to the blade and less so when the grain is going along with the blade.
I use 1/4" Lenox bi-metal 6 tpi hook blades. I'm cutting 1" radiuses so the curve isn't too tight. It tends to abate some for periods of time and I think something has changed to fix it, then it will come back. It doesn't seem to matter whether I've just started the cutting operation or if I'd been at it for awhile, so I don't think the heat of the blade is involved. I've tried running the wood through faster and slower, trying to hold the wood more firmly to the table (although it's the blade vibrating, not the wood) and holding my mouth differently, but I can't figure out a solution.
Has anyone else experienced this and found a way to solve it ?
