Shelf Supports
Shelf Supports
Shelf Supports
Tony - Memphis
I'm working on a design for a builtin bookcase for our great room. My wife has requested that at least some of the shelves be adjustable. I like the look of the holes and pins vs. installing metal standards. My concern, howver, is strength. The shelves will have around a 32" span and she is notorious for overloading...anything. I built her a bookcase when we bought this house and probabaly the only thing that has kept the shelves from sagging is that I screwed them into a 1/2" plywood back. Anyway, I was curious to see if any of had any experience putting heavy loads on the pins? I see that they have the nice little inserts available and the flattened pins. Those look like they would be pretty stout. I'm still working out the design. It will probably sit on a single drawer base, three sections, pilasters with corbels supporting a top with lots of molding. This is a paint and filler project. I needed one after the last two projects I finished (tea table and a set of chairs for the same room).
Tony
Re: Shelf Supports
Re: Shelf Supports
David Hay Denver
I built some built-in bookshelves a few years ago that have spans similar to the length you are considering. Most of the shelves are adjustable via shelf pins. The shelves are just 3/4" plywood with a 1" hardwood strip glued to the front. We've packed the shelves with books and magazines and I haven't seen any problems with sagging or the shelf pins pulling out.
If you're really worried about the weight, you could put a column or two of shelf pins along the back of the cabinet to support the back edge of the shelves.
I didn't bother with the shelf pin sleeves, though I could see how they might provide some additional support by spreading out the weight over a slightly larger area.
Hope that helps!
David
Re: Shelf Supports
I did exactly the same thing
Bruce, a MN Galoot
with a half dozen bookshelves I've made: 1" strips glued to the front, and shelf pins. With the last set for my son, he told me there were two shelves that he wanted extra strong, so I also glue a support strip to the back of the shelf. There has been no sagging.
On my own, I cheat and have piled all my FWW and other coated paper magazines on the bottom. Those suckers are heavy.
Re: Shelf Supports
Re: Shelf Supports
John McGaw
Mine have a 34" span and use 5mm pins in the standard 32mm "Euro" pattern. Shelves and uprights are 34" MDF (budget constraints) and the shelves have a 2-1/4" hardwood strip glued and biscuited to the front edge. There is no sign of sagging with the heaviest loads which would physically fit onto the shelves. Unless I take up anvil collecting I figure that these will be safe.
Re: Shelf Supports
Shelf Supports - Pin - no problem
Terry Alexander
Just finishing up (finally) our kitchen. My goodness but she has a lot of dishes :) NEWay.....I used the shelf pins, 1" hardwood glued and biscuited to the fronts. Also.....on the wide shelves (+30"), I put a pin in the middle in the back.
I've used pins for adjustable shelves for years and (knock on wood) I have never had a pin come out.
Terry Alexander in West Texas
Re: Shelf Supports
Hundreds of holes experience
Bill Tindall
Every closet, pantry and book case in the house has such shelves with 1/4" holes and pins. The woods are poplar, walnut, ash, mahogany. I can not imagine a load heavier than the canned good on some of these shelves. I have no doubt that the metal bracket would fail before the wood. I also have no doubt that I could stand on a 32" shelf supported with 4- 1/4" brackets.
Re: Shelf Supports
Re: Shelf Supports *LINK*
FredD
Pins are the most used form of shelf support for me Tony and in this Ash bookcase in our Library , you can see the shelf loads are substantial and have very little to no deflection in the shelf.
The Shelves are solid Ash to keep a slim line and better book storage and more resistance to sag.
http://picasaweb.google.com/FredD17209/BookCase?feat=directlink
FredD
http://http://picasaweb.google.com/FredD17209/BookCase?feat=directlink
Re: Shelf Supports
Thanks!
Tony - Memphis
Thanks everybody. After some research, I like the 1/4" pins witht he inserts. They look nice. I may get the Rockler Jigit for this. For $35, it lokos liek a nice kit. I'm not sure, but I may just use 12" mdf for my sides if I can still buy it at the box. That's what I used for the last bookshelf. Takes paint real nice. I'm not really equipped to rip sheets of plywood.
Tony
Re: Shelf Supports
Re: Thanks!
Bruce, a MN Galoot
you can make your shelf jig. Norm made a good one using mdf, and then drilling holes sized to fit his plunge router guide bushing. Then plunge cut with a 1/4" bit in your router. It works extremely well, and a router bit makes a nicer hole than a drill bit anyway.
Re: Shelf Supports
Re: Thanks!
John McGaw
I was going to suggest A & M Supply which is where I bought my 12" MDF in 12' lengths. Then I checked and found that you don't have one out at your end of the state. Having the material already ripped accurately to the correct width sure does make the project move along more quickly. I could have ripped the material in the shop but with my cramped space and low ceiling it is a serious PITA not to mention a PITB (pain in the back) that that is one reason I avoid sheetgoods whenever I can.
Re: Shelf Supports
Re: Shelf Supports
I've used pins in many instances. Rockler now has "sleeves" for those who don't have really sharp bits. I like the idea of sleeves.
If the LOYL is really into overloading shelves, I would put a hardwood strip front and back.
Re: Shelf Supports
Re: Shelf Supports
Jim Dillon
Tony,
Like others have suggested, I also have had good luck with the shelf supports with sleeves and fastening a strip of hardwood to the front edge of the 3/4-inch plywood shelf for decoration and increased strength. Regarding the Rockler hole guide, I purchased one years ago when I did our kitchen. Frankly, I never used it as it wasn't long enough IIRC, but made a homemade jig based on the Rockler concept for use on my drill press. I'm having a senior moment right now trying to remember what the jig looked like (and am away from my shop) but I think it was just a long strip of hardwood with holes bored at appropriate intervals with a 1/4 inch dowel at one end to stick in the initial hole. Something like that anyway. I ended up only boring holes in the area where I might want to adjust the shelf rather than along the entire board. I used a nice sharp brad-point bit (Lee Valley) to drill the holes to avoid splintering the veneer plywood.
Jim
Re: Shelf Supports
Use pegboard for the BORG for template
Terry Alexander
I have drilled hundreds (maybe thousands) of holes. I use a piece of pegboard that I cut to fit into the area where I need the holes. You don't want a hole every inch (or at least I don't), so I take a black magic marker and circle either every other hole or every 3rd hole....on BOTH sides. Also, make sure you write "TOP" on both sides of the pegboard or you will/can end up with holes on the left that don't match holes on the right (DAMHIKT).
Works every time.
