Faux cut nails
Faux cut nails
Faux cut nails
Bill Tindall
Sometimes the look of a cut nail is called for but you might not have one because they are expensive and not readily available in East TN, or you might need a nail that actually will hold something. I learned this trick from Steve Headley in our class this week. Take a coated nail, noteworthy for their holding power. Bash its head with a hammer on an "anvil" until the bashed side is flat, rotate 180 degrees and bash the other side flat. File or grind the head back flat across the top. The result is a rectangular head profile just like a cut nail. The coating glues the nail to the wood resulting in improved holding strength. The ground head soon turns black like a real cut nail. This was one of dozens of tidbits we learned in this information dense class.
Re: Faux cut nails
Re: Faux cut nails
R Payne
Having attempted to pull cut nails and having pulled coated nails, I do firmly believe cut nails hold better than any round nail, coated or not.
ron
Re: Faux cut nails
A.J. Hamler
I agree, Ron
A.J. Hamler
As many here know, I make a lot of reproductions for Civil War reenacting and Living History use. I've found that once you've driven in a cut nail (assuming it's the proper size and type), it's there to stay.
Cut nails are square/rectangular in profile, and the stamping process that creates them usually leaves slightly serrated edges on the nail shanks. As far as my experience goes, the only things that hold better than cut nails are screws.
A.J.
Re: Faux cut nails
Re: Faux cut nails
Jim Hoeller
I have found that horse shoe nails have an 'out of the box' appearance very close to cut nails and are no where near as expensive.
