Saw Vibrations/Link Belt
Barry
I have an older Delta Contractor Saw. It has always had a terrible vibration when switched off and the motor is allowed to coast down to a stop. I think the vibration may be coming from the belt. Has anyone used one of the link belts on a contractor saw? Would this help my vibration problem?
Re: Saw Vibrations/Link Belt
Better/cheaper solution
Neal in San Jose
A notched belt solved a similar problem for me on my jointer. Simply take the belt off your saw and take it to a local power distribution retailer (look up "bearings" or "power transmission" in the yellow pages) and have them match the size with a notched belt. Probably 1/3 the cost. Even easier would be if your existing belt still has a readable size, (something like A-48) then you could order one on line. You will need to know the section; A, B, C, etc. and the length, 48, 50...
Doug Ring
Barry,
I while back, I made two modifications that significantly improved the vibration of my Craftsman contractors saw:
* Switch to a link-belt
* Added a 1/2" think aluminum spacer plate between the motor and the motor mounting flange
I think the flange probably had the largest impact, as it made the entire motor mounting assembly much more resistant to twisting.
Rick L
Re: Cogged belt!
Rick L
Cogged belt from mcmaster. Link belts are overrated?
Barry, I've been using Fenner drives [link belt] on all my machines for many years; very pleased.
Are they better than "AX" series [cogged] belts? Can't really answer that, but I can tell you they are way way easier to change. You do, however, have to be careful to install they correctly with the tabs running in the sheave and the little arrows on the outside surface pointing in the direction of rotation.
Another source of vibration is the "stock" sheaves supplied with some machines. Adding accurately machined (all surfaces) sheaves to your motor and arbor can make a big difference. You also want to check your sheaves to make sure they are tight on the shafts and running true and parallel.
Lastly, you can check with a motor shop. There is an phenomenon with electric motors, I think called "regeneration", which, as the motor slows down with the power turned off, will cause the sound you are describing.
Barry
Some time ago, I called Delta's Tech Support and complained. They mentioned an electrical phenomena like you describe. They sent me a resistor to wire across the motor terminals. I could not see much improvment, if any. I still think the vibration is from the belt. I'm beginning to think it is just peculiar to contractor saws because of their design with long belts. Thanks.
del schisler
I use a link belt on my saw just like your's. It sure did make a lot of difference. I wouldn't be with out it. It start's smooth and run's very good. I know you would like it. It sure will make a beleaver out of you . Also i have a saw blade that doesn't fit the arbor like it should. It is a little bit over size so i get s very slite vibration now. The blade is running like egg shape when it run's. Still i use the blade. It is not that bad. a few thousand's i guess don't care cuts what i want.
Keith Newton----Little Rock, Arkansas
I replaced my old belt with a link-belt, and feel like it improved some of the vibration due to hard memory crooks in the old one. It did help that, but I don't like the whine induced by the links, so I believe I might replace it.
I also use a spacer, only wood, on the rods, which holds the mounting plate away a bit. It has been on there so long, I have forgotten what problem it solved.
As for the vibration after turning off, I believe the problem comes from the motor climbing the belt on the top side due to a difference in the rate that the saw arbor, and motor would coast to a stop. When the saw is running, the motor is pulling the bottom side of the belt. When you switch off, the blade and arbor coast is freer than the motor, causing the motor to climb the top of the belt, then loosing traction, dropping back, and doing it again.
Fix It!!!
Del, you're tap dancing on a land mine! putting uneven stress on the teeth of that blade will cause metal fatigue and can easily result in fracture of both the plate and brazing if carbide tipped. The thing can come apart at any time with disastrous results for you and/or someone else near the saw.
From what you describe it appears that the arbor hole was overbored. That is a defect that should have been caught by inspection at the plant before the thing was ever shipped. If they missed that obvious defect, what else did they miss and what latent defects in the blade are just waiting to injure or kill somebody?
Please, please, either fit the arbor with a bushing or pitch the blade!
Chuck Jurvelin
Several years ago, I replaced the stock belt on my contractors saw with a link belt and also replaced the pulleys with the machined turned ones. This, along with spending considerable time making sure the motor/arbor alignment was right on, made the saw perform significantly better. I have since added link belts to a number of my tools and despite the cost, I definitely find it worthwhile, especially on tools like my lathe that doesn't get used very often. Regular belts develop a memory when not used and therefore add to vibration.
Howard Acheson
To answer your question: Yes, you can use a link belt on a contractor saw. I have been using on for 10 or more years. I'm not sure it reduced vibration but it sounds different. I never had much vibration anyway. The belt was free so I put it on.
Re: Saw Vibrations
Your saw may be picking up and amplifying an harmonic as the motor passed through a particular speed range. You would hear it on startup because of the difference in time it takes to get up to speed and wind down to stop. Check your mounts as a slightly loose nut will do this as well. I have one friend who actually puts a torque wrench on every nut on each machine to make them all match. I seriously doubt it makes any real difference, but it satisfies his OCD so that's ok. ;)
FredD
Nothing like a little excitment while in the shop , huh Del?
FredD
Did Fix It!!!   *LINK*
del schisler
I been using this blade for a couple yrs. Have cleaned it and still cut's and slite vibration. I use it every day and nothing has happen. Guess lucky . Been buying loto ticket's but nothing their. This hasn't been any problum tell i change blade's and now smooth. Oh well guess i will put on the next new one and see what happen's . I have a call to dewalt to see what or just to give them their long over due 2 cent's worth maybe get me pissed and then the whole nickel worth. The blade is this one It is on sale for $14.55 check this site. thanks for the concern del
http://www.toolking.com/power-tools/saws/table-saws/table-saw-accessories/table-saw-blades/dewalt-dw7657-10-inch-40-tooth-general-purpose-blade/
Now
Clean it up, and send it back to Dewalt pointing out the defective arbor bore. If they're smart, they'll breathe a sigh of relief that nobody got killed and send you a new blade!
:D
I have a forty year old Delta Rockwell Contractors Saw. Several years ago I replaced the pulleys with machined ones and a link belt. I can not say there was a significant reduction in vibration or improvement in the cut, but what did happen is it stopped throwing the key out of the motor pulley. I did not even know you can put a set screw on top of the set screw, so I was using loctite and installing a new key about every other year. Now the saw runs and cuts great and I have not had a problem with the key in about five years.
Chuck Lenz
I installed a link belt on myMade in the USA Delta Contractor's table saw a few years ago, also makeing sure that the pulleys were inline with eachother. I wired the saw for 230 V and it purrs beautifully. I haven't noticed what the motor does after I shut it off because I could careless, I could also careless if the belt sounds different. What counts to me is how it performs during a cut, and I have no complaints in that department. The motor may jump a bit more then some machines because of how the belt is tensioned with gravity and not a fixed tension, It's kind of the nature of the beast. It's also hard to tell if what you think is a problem is any worse then what any other persons Contractor's saw does without being there in person to see what it does. I will say though that I think Fenner is priceing themselves out of the market. I use to be able to buy the 1/2" wide link belts in bulk locally at Motion Industries ( suposedly one of Fenners largest customers ). The last time I called there, a couple weeks ago the guy said they were out of it and had no plans of restocking because he can't remember the last time he sold any. So I went to our local electric motor shop and had a discussion with him about the belts, he wasn't interested in stocking them because he felt they were to overpriced, 6 times the cost of a regular belt. I'm still a believer in the link belt not only because of reduced vibration, but if I ever sell a piece of equipment that I have a link belt on, I can take it off and put the original V belt back on, then resize the link belt for whatever piece of machinery I want to put it on.
Del?  On Second Thought *LINK*
If you've been using a 5/8 bore blade on a 1/2" arbor, I doubt Dewalt's going do much for you except tell you to get one of these . .
OTH
5/8" blade  on 5/8" arbor delta contractor saw
del schisler
i have a call into them Dewalt . Nothing heard from them yet. I may call again. I didn't mean to hijack the therad.
You didn't
delta is replacing the blade NO cost
del schisler
I called dewalt and that call is to delta which i guess took over delta?? i told them of my blade. They said they will send me out a new one at no cost . Glad to get it replaced. I guess wonders never sease. To much for a company not to take of the cust's
