Favorite recipe for waxing up a cast iron table?
wilbur
I want to apply something to reduce the friction of boards moving across the table of my bandsaw. Lots of options out there: paste wax, microcrystalline wax, Boeshield, TopCoat, etc.
What's your favorite way to get a cast iron table nice and slick?
If it matters, I'm lucky that my basement shop is dry enough that I don't have to worry about rust being an issue.
Re: Favorite recipe for waxing up a cast iron table?
I scrub my cast iron with a suitable solvent (mineral spirits and an abrasive pad) and after it's dried, I use Renaissance microcrystalline wax and polish it.
I have used paste wax and it works well too.
Moses Yoder
Moses Yoder
My favorite method consists of 1 part Johson's Paste Wax and one part Elbow Grease. Simply apply the paste wax with the elbow grease. This does not cause any problems with finish and is slicker than a skating rink. One thing to watch out for if you decide to use a spray instead is the floor in front of the saw tends to get slippery.
Dale Lenz
TreWax
Dale Lenz
For my money.....
David Yoho
I generally grab what's been working for me all these years - some Johnson's paste wax. Recently I was running a lot of rough stock over my jointer and realized it was harder to push along. I stopped what I was doing, applied some wax, buffed it dry, and went back to working the stock. It glided across the jointer like it was on roller skates.
Now there's a lot of great things on the market that will make cast iron slick while providing some protection but nothing is less expensive than plain old paste wax and it works well.
Waxilit
I believe a couple of our major sponsors sell it. Good stuff.
Second the motion; cheap and very effective.
doug f, san clemente, ca
DavesNotHere
A layer of TopCoat first for rust prevention and a little slipperiness followed by a couple of coats of Johnsons Paste Wax for a lot of slipperiness. :D
home made wax is best
Bill Tindall
Dissolve some Carnuba wax in hot xylene or turpentine(preferred). Let cool. The consistency should be mushy when cool. Apply with a piece of sheep skin or equivalent.
Carnuba is reported to be the hardest wax so it follow that it would be best for this application.
steve mackay
TS table, hand planes, hand saws, ANY bare metal . . . Johnson's Paste Wax.
Does a GREAT job on floors too !
Little difference in paste wax
Howard Acheson
In my 50 years of woodworking I have used a number of brands of paste wax. The list includes Simonize, TreWax, Johnson and Minwax. I find little difference in any of them. Currently I have ended up with two cans of Johnson Paste Wax so that is what I use. More important than the brand is the frequency it is used.
BTW, the solvents in wax will dissolve an prior wax on the surface. Therefore, it does no good to put on more than a single "coat" of wax.
I agree....
Ron in Sterling, CT
Brand doesn't matter. Any good paste wax will do. I have a can of butchers wax, and a can of min-wax, and I can't tell the difference. I can tell though, when it is time to re-apply the wax.
Ron
Boeshield T9   the best
del schisler
Steve Kirincich
I have heard of people who have sprayed a coat of lacquer on their table saw tops and have been very happy with the results.
Re: home made wax is best
wilbur
"Dissolve some Carnuba wax in hot xylene or turpentine(preferred). Let cool. The consistency should be mushy when cool. Apply with a piece of sheep skin or equivalent."
Step 1: Get a chunk of Carnauba wax and some turpentine.
Step 2: Find a sheep who happens to be looking in another direction.
