Corner blocks - attaching?
Gary Smyth
I have to attach supporting corner blocks at the mitered base of a cabinet (tall 72" and almost 100 lbs). At this late stage of doing this I thought I'd ask. How do I attach these? It seems to me that the corner blocks will be cross grain however I attach them. The blocks are oak 2" square by 4" long and hide behind maple base skirts. Are they small enough-too large-to glue? I have placed corner blocks before but on a smaller scale and I used glue. Problem is I have no idea if that was correct. So far for past work, no trouble, but maybe that was just luck. I have looked in furniture drawings for traditional furniture and can find smaller blocks but no narrative indicating how they ought to be attached. I have found references advising that the weakness of fine traditional furniture is crossgrain failure. The oak blocks are overly large because I was going to attach "hidden" casters, but I'm thinking now that that would exert too much stress on the base (especially on carpet) considering the height and weight of the total piece. Now I can't get my head around what is good woodworking procedure. Someone please refresh my brain.
Re: Corner blocks - attaching?
Joseph Mulherin, Sr
Gary, what I would do is instead of using he oak I would use douglas fir 2x6 blocks cut in a diagonal fashion, placed in the corners and pin-nailed using glue also. They casters could be screwed to the 2x6 nicely and not hit the cabinet corners when turning...and should not split either.
The traditional way...
... is to use hot hide glue and just rub the blocks until the glue sets up. Works great. If you would rather use cold glue, you can drill screw holes in both directions and screw them in with glue, or nail them, as someone suggested.
The size sounds pretty large. 1X 1s should do the trick.
The size is large but
Gary Smyth
could be cut down. I made them large originally so that I could to drill for the post and plate of an old style caster. If I eliminate the casters the blocks can be any size smaller. If I use glue and screws in both directions to set the blocks into the wrap around base skirt you don't believe that small area will cause the base to split because any expansion will be horizonal on both -- the front and the sides. Am I understanding you correctly? Finally, without casters should the block set slightly above, even with, or slightly below the base? Does the cabinet set on the base or the blocks?
Re: The size is large but
FredD
Gary expanding on Ellis a bit , your size is really large for a Glue block which is the traditional name , rip a 1"x1" on a 45 degree angle and cut into blocks about three or four inches long and like Ellis says rub back and forth a couple of times and don't worry about cross grain glueing.
FredD
Revised comment
Sorry Gary, I thought you were talking about glue blocks. Your 2x2s will be fine for the corner blocks. I don't know how tall your base is, but screwing the block to it shouldn't be a big cross-grain problem. You can taper the holes a little to allow the screws room to deflect a bit. In the dressers and chests I've seen, the corner block itself is the actual bearing surface. If you plan to use casters, you'll want to make the block larger and recess it, allowing for room for the casters to rotate.
Just had a class on ths topic
Bill Tindall
The best corner block, providing the feet never get wet, is one prepared like plywood, except the "plies" are 1 or more inches thick. The alternating grain direction provides ample glue surface to the base/skirt while matching cross grain expansion. We were told though that these blocks don't survive setting in water well.
If the base is not too high then a traditional corner block running cross grain is acceptable and it is what will be found in most antique furniture. The block carries the case load.
One can make an acceptable rub joint with any common wood glue.
Please go over
Gary Smyth
the make up of the plys again. I can chop saw or band saw the oak any way necessary. The way the stock sits now it's one piece 2" x 2" x 24 ". Are the plys "sliced" horizontal or vertical?
a picture would be worth a thousand words....
Bill Tindall
if I just had one. This may not be the most efficient way to make a "ply" block but for example purposes maybe it will be easiest to describe.
Cut 5- 2 x 2" pieces from an inch thick board. Glue them together to make a post 2 x 2 x 5" tall. Every other board is rotated 90 degrees in the assembly so the assembly resembles plywood, except the plies are an inch thick.
The practical problem is that by some means one must wind up with a block that is smooth on two adjacent sides where it will be glued to the base. Hence, this sort of block was not typically used in period furniture construction because it was too expensive to make.
Cut
Got it
Gary Smyth
