2 x 10's
Doug Ridley
Exactly how wide is a 2x10 these days?
2 x 10's
Doug Ridley
Exactly does not apply....
I believe the current standard is 9 1/4", but they seem ta vary from about 9 1/8" to 9 3/8", 9 1/4 being sort of an average. Treated lumber is often soaking wet when you buy it and is often 9 1/2" or more wide and drys to something near 9 1/4". Not sure about 2 x 10's but on the east cost western lumber is often labeled S-Dry which indicates it is cut and milled wet and dries in shipment across the country. I know they do this with 2X4's, not sure about larger stuff.
Re: Exactly does not apply....
Doug Ridley
Thanks
Barry's got it right
My local contractor's lumberyard states that dimensional lumber may vary by 1/4". The standard for Doug fir 2x8s and up is the nominal dimension less 3/4", so a 2x10 could be anywhere from 9" to 9-1/2".
And this is from a pro's yard, and has been true for some years.
I'm in the midst of converting a storage shed we built some years back to a workshop (it's overbuilt on a slab, so this means mainly running in electricity, adding windows, insulating, finish walls/floor), and was quite grateful for my power planer, as I had to reduce some 2x6s that were on the high end of the tolerance so I could have a faint hope of having flattish sheetrock.
FredD
Your confused about the meaning of the S-Dry stamp on construction lumber . It means that the lumber was "surfaced dry", at least as dry as 19% MC
IF it was surfaced green ,which means wetter then 19% MC then the stamp would say "S-Grn".
Also I doubt you will see any West coast lumber on the East coast, it more then likely will either be Yellow Pine from the South or like here, from Canada.
It doesn't make any difference where it came from, the stamp means the same everywhere and does not relate to shipping .
FredD
