A55 Smoothing Plane
Dewalt Biscuit Joiner
Barry
What's up with the above. Since it's introduction, the above has sold for $189.95 to $199.95. My local Lowe's now has it for $149.95. Is a new model in the works? I've never been much of a fan of biscuit joiners, but I almost have an urge to go out and snap one up while they are $40 to $50 off.
Re: Dewalt Biscuit Joiner
Tom Pilsbury (Chicago)
It's not an absolute necessary tool but it comes in handy and they're kind of fun to use. That's a pretty good price. I paid $139 on sale at HD several years ago. I don't use it often but I like having it around. I say go for it.
Barry
That's about the way I feel. Not a necessity. but would be nice to have around. Maybe I'll just get a new carbide blade for my tablesaw. Or new knives for my planer. Or, both.
FredD
You can't beat them for fast strong Face Frame assembly.
FredD
Richard McComas
That what I used to think until I went to pocket screws.
Moses Yoder
Moses Yoder
Well you know Fred I respect your opinion but have to respectfully disagree on the biscuited face frame. Maybe if you use wide rails. The one kitchen I saw that was made with biscuit joints in the face frames had the corners of the biscuits sticking out in each joint and all the joints were coming apart. They had to replace the kitchen after only 5 years or so. I quoted them a price for a brand new kitchen.
I have the Dewalt biscuit joiner, think I paid the $190 for it, and have always thought it was a pretty good tool for the money.
Clint Searl
Indispensible
Clint Searl
Especially for aligning long edge joints. And the biscuits don't have to be glued in, as the contribution to strength is irrelevant in a properly mated joint.
Clint
A Generic Downside
[I have a Dewalt as well]
Not recommended for joining veneered plywood or most anything under 3/4 thick. Reason being that using PVA glue so the biscuits swell for a strong fit will cause the wood to swell slightly. The biscuit shapes will often "telegraph" to the surface. Sanding too soon may cut the top surface even so that when the moisture disappears you've got these little football-shaped depressions all along your joint. In the case of ply, if you don't sand flat, the plies may never go flat and you've got bumps which if you then sand, you wind up cutting through the veneer. The answer to the telegraph problem looked to be the Gorilla/urethane glues, but then the joint failures started . . .
I use biscuits to glue up solid wood panels, but I set them closer to the hidden side of the workpiece and then leave extra time for the joints to fully dry before finishing.
FredD
Well Moses, I welcome different views based on empirical evidence , but it seems to me that you formed your opinion about face frames and biscuits assemblies ,based on one badly done job that naturally failed, just like any joint not well done by a amateur.
I have many cabinet jobs with face frames assembled with biscuits and no failures.
On the bright side , the guy who did the job badly got you a Kitchen job and the chance to leave a happy client.
In reply to who posted his delight in discovering Pocket Screws , Tsk ,Tsk.
FredD
George Colonel's Workshop-Havertown PA
Good Afternoon Barry,
I have had the DeWalt since it was introduced back in the olden times. I forget how much I paid but remember it was expensive. Retrospectively, I am glad I have it, and use it infrequently. I like it best when mitering corners for large mirror frames. I am not convinced that they are all that much better for alignment, as I still need to hand plane and sand copiously before a panel looks and FEELS acceptable. Had I to do it over again, I'd not be so committed to getting a near top of the line DeWalt or P+C. I think Norm probably convinced me of the necessity of using one with his Lamello. I'd now buy by price and be content.
George
Re: Indispensible
Steve Schoene
But, unless your technique is superlative and your machine well tuned (or Lamello Top 10) using biscuits to align edge joints can as easily assure minor misalignments. Using cauls to align edge joints is much more likely to get them really closely aligned
Re: Indispensible
FredD
I have always believed that a power tool in the hands of a newbie will only let him make misakes faster, while one who is practiced in the use of , like Clint says , "it is indispensible"
FredD
