15 in planer gear oil
Normp
It is time for me to replace the gear oil in my 15 in. Jet Planer. The instructions make a vague reference to 50 weight gear oil but I can't find this, at least so far. I typically find higher weights 70-90. Any idea what 50 weight gear oil translates to in off the shelf oil?
Preferably someone who has replaced this gear oil in the planer transmission.
Norman
Re: 15 in planer gear oil
Re: 15 in planer gear oil *LINK*
John in NM
50 wt gear oil is not at all common. It's not the same as 50 wt. crankcase oil. Double check the instructions, and if you must have 50 wt. gear oil, I doubt you'll find it in your average parts store. Most articles I saw in a quick google were more concerned with explaining multi-viscosity crankcase oils, but there's one that did have a nice little graphic comparing gear and crankcase oil weights - see link.
Planer crank case is going to be fairly low speed as these things go, just about any gear oil should do the job. Lucas and BG make a big deal of their "high tech" oils, so you could send either an email and see what they recommend, both companies seem to make fine products.
Oil explained
Normp
I downloaded the Powermatic 15 in. planer manual. It is the same planer, at least identical looking. Their specs for gear box oil are different, they specify 70-90 weight standard multi-purpose gear oil.
The chart at the link you provided shows that 50 wt. translates to SAE 90 weight,, It makes some sense now.
I can source this easily so I'll use this.
Norman
