Restoration project - cleanup help
Todd
Hi everyone,
I've got a bit of a restoration project I'm working on. It's my great grandfather's buffet from sometime ~1930, and I've got my work cut out for me. I don't think it had a finish on it originally. Then my grandfather painted it. Then my parents stripped it. Then they put it in the basement, where my brothers thought it was a good place to stash all manner of stuff when they were kids. In any case, it's had a rough ride.
It's solid oak plus some oak veneer. It has some mold in it, so I wiped and sprayed (spray gun) denatured alcohol in it to try and clear that up. That's the first thing. I want to clear that up for safety. I'd like to avoid damaging it any worse, but safety comes first. Anyone dealt with situations like this?
Next comes the top. It looks like something might have been glued onto it at some point. Not sure. Anything would have happened over 30 years ago. Any suggestions on solvents to try to clear this up? Any technique advice would also be appreciated.
Also on the top, there are a number of holes, maybe from nails or pegs. I'm not sure of what to do there. I was thinking maybe of drilling them out and putting in some plugs. Probably oak rather than a contrasting wood, since the whole thing is oak. Any other suggestions about what to do here?
After I figure these things out, I'm planning on a coat or two of shellac, followed by lacquer. I appreciate any help getting there. After this would come the (hopefully easier) restoration project, my other great grandfather's table. Some pics are below. Thanks!
Bigger images on flickr. http://www.flickr.com/photos/15956122@N06/5156137211/in/photostream/
Re: Restoration project - cleanup help
Gary Smyth
For the mold use straight household bleach. Wipe it down with non steel wool scrubber, let it dry, repeat. Not too wet and it will bleach the wood some especially with porous oak. Bleach will kill it on contact. What is left, if any, will be sealed by the finish. Make sure it is dry before finishing.
DouginDenver
I have recenlty been restoring several old family pieces. Hard to say for sure given the small pics, but frankly that doesn't look like too bad a project at all. The top appears to be quarter sawn oak. What you may have to do could depend on whether the top is solid or veneer. First, you have several stripper options. Since you don't know what will take the goo off the top, focus first on the rest of it. To take off old varnsih type finshes, I never use the thick methylene chloride type strippers. Those are great for layers of old paint, but I find them less than satisfactory for varnsih type furniture finshes. I recommned you get a liquid furniture stripper made just for that purpose - a Formby's Furniuter Refinisher type product. I found one that my local True Value sells much cheaper than Formby's that works better than anything I've ever used. I can get the name if you want it. It's light blue - kinda like Windex - and almost looks like it has small silvery fish scales in it. It really works well. You could have that whole desk to bare wood in a couple hours. Then try that on the top and see if it works. If not tyr some of the paste type strippers - the strong stuff - not the citrus ones - or they even make strippers just for the flooring adhesive stuff. One of those ought to work. If that fails, or the glue has stained the wood, you may need to remove part of the wood - that's where the sold wood/veneer question arises. As for filling holes, post closer pics or descrbe them by shape/size and we can give you suggestions.
Todd
Thanks to both of you Doug and Gary. I'll test on the inside with the bleach (that's where most of the mold was anyway).
Regarding getting rid of the old finish, well there really isn't much to remove. There is a small stripe of white paint on the edge of the top, but I'm not worried about that. Other than the top, the rest is already stripped clean. I'll give your suggestion a try with the blue stripper from true value. I'm pretty sure it's a solid top as I can see the edge grain at the back.
With the holes, a friend today suggested it might be for a rail or something similar (keep things from falling off). You can see bigger pictures on flickr.
http://www.flickr.com/photos/15956122@N06/5156748610/in/photostream/
Joe Mohnike
Prior to attacking the top, look at the top from the inside, if you have too, sand a small area and make sure it is a solid top.
I would remove the old finish first with a good stripper. I use a paste or semipaste remover, they work well, and trap the old finish and will remove some of the dark spots. Clean up per mfgs. instructions.
Part of the black or dark spots may be from when something metal was set on the top and got wet, this will turn oak dark in a hurry. I use a mix of 50/50 water and household bleach in a spray bottle, you could also try Oxcilic acid to remove the stains. Either way it leaves the wood almost white but when you sand some of the stain reappears. You may have to play around with your applied stain to try and mask the discoloration.
Try and find some old family photos which may have the piece in the back ground, this may tell you what the holes were for. There could be side pieces or a rail of somekind in the front which are now missing and the photos will help in trying to duplicate them.
Sounds like a fun and worthwhile project.
Good luck
Joe
