OT Great Stuff in bulk question
I bought a house at foreclosure and am fixing it up for my son and his family to live in. It was going to be a rental property but they want it. So I am thinking about how to insulate it and seal it better. Been using some Great Stuff foam in both of its forms.
My Question is can it be had in larger quantities.? Is there a bulk version? I can think of a lot of things to do with it but Great Stuff is very expensive.
Re: OT Great Stuff in bulk question
Don't Go Overboard
As a house inspector you know that if you seal things too tightly you get mold and poor interior air quality.
I used it to seal my sill plates on the outside and between window jams and the RO framing. Doesn't take much to do that.
Has to be a place on-line that'll give you a case price.
There are similar spray foams that can be had in larger quantities. 4,000 cans of Great Stuff would be an expensive way to get the job done. You might see if there's a local contractor's lumberyard or supply house that can show you the possibilities.
Tom MacGregor
It's possible to get bulk tanks of foam that attach to a gun with a hose. Foam, however, is not a one-product cure-all. The largest source of heat loss in most buildings is air infiltration. You could waist a lot of money on foam when what you needed was tighter windows and weatherstripping. For the cost of a case of foam you can probably get a weatherization crew to do a "blower door" test on the structure and make a list of recommendations based on the latest accepted practices. You could then choose what to do - on your own or contracted - knowing you are applying the most cost-effective solutions in the long run. For instance: It's been found that in many homes the space around the outside of the chimney is the largest single source of heat loss by moving air very efficiently from basement to attic. Missing that one would compromise the effectiveness of your job, and flammable foam would not be the appropriate product.
MR Foamy *LINK*
Dustmaker Mike
Here is a site that has what you are looking for. I am going to insulate my shop with this stuff.
Mr Foamy
