Board Buddies
Board Buddies
Board Buddies
Brint in Richmond, VA
I'm in the process of finally finishing all my unpacking, sorting, organizing and putting away all the stuff that was in my garage shop when we packed up to come to Richmond from Atlanta (3-1/2 years ago - !), and unearthed my set of yellow Board Buddies. Between here and there I switched out my $199 Skil tablesaw for a used Grizzly 1023Z, which came with a Shop Fox fence that has a T-track on the top. The Board Buddies mount, slide and position on the fence just fine. The problem is, even with the eye-screw adjuster fully backed out, the wheels only lower to within 1" of the table - which means they're useless for any stock thinner than that (like 3/4" cabinet plywood, etc.) The fence itself is about 3-1/2" inches tall.
Does anyone out there with Board Buddies have the same experience? I can't see any way of adjusting them to set closer to the table.
Re: Board Buddies
Re: Board Buddies
George
I've had my Board Buddies for a really long time and have always liked them. Every now & then 1 won't adjust down to the board thickness I need. It seems that the plastic slider inside the housing gets cocked in its track and won't slide back. I have to tension the spring and wiggle the slider to free it & then its OK. The spring is pretty strong, though, so I am justly afraid of having it do damage to my fingers; BE very careful!! HTH
Re: Board Buddies
Re: Board Buddies
Hal
I think it's the height of your fence. I've used "yellow wheels" for many years and wouldn't be without them. Have then on a Beis fence now which is only a little over 2-1/2" high. When I first got them, I had a Craftsman with no way to mount the track so made an auxiliary fence, and because of the height, I sloped, or chamfered, the front of the fence from the toes of the mounting plates at 60 degrees as I remember. This allowed the wheel to lower enough to accomodate 1/2" (I think) stock. I know they would accomodate 3/4". This might work for you. As I remember, I left the aux. fence on most of the time, even when I didn't use the wheels. Good luck. Hal
