Circle cutting jigs?
I have a couple.
One I mount on my band saw. I drill a small 1/16" hole into the bottom of the board that I am sawing. I mount the board on the band saw with a clipped 4 d finish nail through the jig into the bottom of the board. Slide into the blade and start cutting. The only drawback to this one is that I do need to put a leg on it to stabilize it.
One is a router jig. I mount the router to the paddle end and have a larger nail in what will be my center. I usually have the board sitting on some scrap on my bench. I then rotate the jig and gradually lower the bit until I have cut through the board all the way around. The drawback to this one is securing the work.
For smaller circles (less than 10") I use the lathe.
I'm reasonably happy with the band saw jig - except I do have to put a leg on it. I like the finish that I get with the router jig - but it makes more noise and mess.
What other circle jigs are easy to make and use? I suppose I could mount a jig saw to a trammel - but that is sort of like the router jig.
TIA
