OT - staircase railing hole "repair"/reinforcement
The stairs over at the playhouse are concrete stairs. The "shaft" in which the stairs are contained has cinder block walls. The stair hand rails are coming loose in some locations.
The existing holes in the cinder block have lag shields and screws. The lag shields appear to be ~3/4" in diameter. In some places, you can pull the railing out of the wall and see the lag shields.
Obviously - they need to be fixed. I was considering larger lag shields - but as the lag shields are loose, I don't think I want to go that way. My next thought was patching with mortar or cement. I then thought of epoxy.
Right now I'm leaning towards an epoxy. Any other thoughts or better ideas? Cheap is very good.
TIA
