OT-making a wooden sign
Steve Kirincich
I am making a wooden sign with ceramic letters, and I would appreciate any input regarding the best way to connect the tiles to the wood. A direct attachment with any of a variety of bonding agents would seem problematic due to wood movement. I have debated the merits of attaching the tile to an inert substance such as phenolic (plastic), and then screwing this to the wood. Help!
Steve
Re: OT-making a wooden sign
How about Hardi-Plank
Ray - Middletown, IN
It comes in 4 x 8 ft sheets, face the ply with it and attach the tiles with epoxy or even a waterproof mastic.
Ray
I asked about this at a tile store in connection with a project I'm contemplating, and was told there's a mastic available at tile stores (in huge buckets) and Home Despot (in little buckets) that meets this need: it's flexible but holds well.
Moses Yoder
Moses Yoder
It seems to me that silicone caulk would work well. It holds good, is weather proof, and flexible. If you are painting the wood then perhaps the paint might tear off but otherwise I think silicone would hold well. I stuck some small pieces of vinyl siding over little holes in my siding with silicone caulk and it has held tight now for years.
Clint Searl
No problema
Clint Searl
Either silicone caulk or PL polyurethane construction adhesive.
Clint
Keith Newton----Little Rock, Arkansas
You are correct that attaching the two could be a problem. And the larger the letters are, the larger the problem. I have no idea whether you are talking 3" letters or 12" or larger, since you didn't mention it.
However, I just wanted to point out, that it is important to not just choose a flexible adhesive which will stick to both parts, there needs to be enough thickness to the adhesive for the elasticity to work. You may need to hold the tiles away with spacers to achieve this. You would not expect the thickness of a rubber band to stretch as much as along it's length, and pressing it in too close is asking it to do that.
