How to get Urethane off hands?
I was trying to seal up some of the holes in the house we are remodeling and got Great Stuff one my hands. I tried paint thinner while it was still uncured. Did not work. So I have dark brown stains that seem permanent. Accidentally, the little patch I missed and wore home as foam pealed right off, so that might be a lesson. IIRC the instructions are to abrade it off. Any better Ideas?
Re: How to get Urethane off hands?
Nat Robison
I think it's similar to dried CA glue. You just need to give it a few days to wear off. I'd probably prefer that route to soaking my hands in solvent.
Quick go rob a bank
Dustmaker Mike
you won't leave any finger prints :D Just use the correct hand. The only way I know of is wear it off. I have a few bags of sand I toss in the back of my truck in the winter and I use it to sand it off.
Acetone
Great Stuff dissolves marvelously with acetone, which, fortunately, is relatively low in toxicity. It will dry your hands out hugely, and is not completely harmless, so clean your hands off immediately, and use some hand lotion.
Best is to use disposable gloves when using it. Any day now, I'll remember to do that when I use it.
not after curing
Bill Tindall
Once it crosslinks nothing will dissolve it. Before curing acetone is an excellent solvent.
Agreed
I was suggesting what should have been done while it was still uncured - didn't make myself clear.
Time and skin flaking off from wear are about it once it's cured.
Gerald Gibbs
My experience with Gorilla glue is that it just takes 2-3 weeks.
Clint Searl
The only things permanent are death and taxes
Clint Searl
Making volcanoe's
Barry My former wife was building a volcano to show the kids at school. She was using Great Stuff. It started off great but as the stuff swelled it began to sag. So she used her hands to help form it. Then she screamed for me and said her hands were getting stiff. I said (may be why we are divorced) "didn't you read the instructions, it says not to use your hands". Well long story short we used every solvent I had and I must have been a chemist in my last life because I have a little bit of everything. Anyway none of them worked. She slowly over about a week, peeled all of the stuff off and took some skin with it. I haven't liked Gorilla glue ever since and will only use the Great Stuff for what it was intended.
Re: Lacquer thinner works on some.
Larry Clinton Sr.
I'm not sure if it works on both types - One being the standard "Great Stuff" that will warp window & door frames if injected beside them (damhikt). The second is the non-pressure expanding "window" foam. I have removed one - believe it was the standard type - using lacquer thinner. Since that episode, I have ALWAYS worn rubber gloves and throwaway clothes. (seems like I always get some dripped on either my pants or shirt, and believe me it will never wash out)
Larry Clinton Sr.
I'm not sure if it works on both types - One being the standard "Great Stuff" that will warp window & door frames if injected beside them, (still have a couple windows and a door that slightly binds). The second is the non-pressure expanding "window" foam. I have removed one - believe it was the standard type - using lacquer thinner. Since that episode, I have ALWAYS worn rubber gloves and throwaway clothes. (seems like I always get some dripped on either my pants or shirt, and believe me it will never wash out)
Re: Acetone...good stuff
Marv
I'm never without it. Always have a second gallon of it on the shelf.
Marv
