Another kitchen "Saga"
We started stripping the cabinets a bit ago.
Before picture
The LOML wanted a microwave above the range. The old cabinet wouldn't do. It had pine 1 x 12 side and it wasn't flush. So - I had to build a new above the range cabinet. Wouldn't you know that I built it too deep? The microwave couldn't exhaust properly. So I had to saw off the back and make the cabinet less deep. Which meant I had to rout the back rabbets and rout the shelves down to fit. Sigh.
I then had to rewire the range. The old wiring didn't fit in the 1-gang box. So I had to get a 2-gang box and cut that into the wall. I needed more wire, so I had to put a junction box in the basement to get another couple of feet of wire. Anyway, the uppers are mostly done. I'm going to the lumber yard tomorrow to pick up some crown molding for the top.
After picture.
Re: Another kitchen "Saga"
Do you want to order a new
Gary Smyth
microwave today, or next month? I hesitate to write this because of all the work you put in. I had a similar arrangement with the microwave above the range. I bought three microwaves before I put back the fan. Unless you don't want to make pasta, iced tea, boiled eggs, whatever sends out vapor, I would tell you to be aware that every bit of moisture generated by the range top will sneak into, attach itself, and condense in the microwave until one day (if you're lucky) the thing doesn't start. If you're unlucky be prepared for a flash, pop, and the microwave or kitchen circuit breaker tripping. Then put on a clean pair of drawers-and I don't mean the cabinet kind of drawer. It will scare the devil out of devil food cake!
You can try to seal the bottom of the microwave, but, from experience, it doesn't work. The enclosure wasn't designed to stop moisture in heavy doses over a period of time. That vapor finds the smallest of areas. Enjoy it while you have it set up for as long as it lasts, but be aware that over the burner microwaves are more risky than putting it elsewhere. What did you do about a fan?
Moses Yoder
Re: Do you want to order a new
Moses Yoder
We have had our over the stove micro for at least 5 years now with no problems. It is made to put over a stove and has a light underneath plus a vent fan with charcoal filters built in, a combination vent/microwave. If you put a regular microwave over a stove I would understand having problems with it.
question?
Bill Tindall
You were able to remove all the white pigment? Please provide details of the stripping process.
Jim DeLaney, Austintown, Ohio
Re: Last one lasted 18 years
That was in my house in SoCal. The current one, here in my Ohio house is six years old, and still works like new.
Sorry, I fail to see the problem...
Moses Yoder
Re: question?
Moses Yoder
I notice kind of a white tint in the finish from the paint in the pores I think, but then I see a lot of cabinets here at work. Perhaps that is just the picture quality too; it's kind of hard to tell.
We had one in the old house for many years without trouble. We also had one in our old town house without trouble. I'm not that worried.
Couldn't remove ALL of it.
Just the vast majority of it.
As I was doing this indoors, I used multiple applications of Citristrip. I applied per the directions. After scraping, instead of scrubbing with abrasive pads and mineral spirits, I just brushed on more Citristrip. I did this several times. I then scrubbed with abrasive pads (coarse to fine) and mineral spirits. I sanded at the end.
Another possibility...
John in NM
Is just plain lousy manufacturing. I've had similar problems with cheap pressure washers, some even failing within waranty. It'll be interesting to see how it goes with the exhaust fan installed, if you don't have another microwave failure, odds are good your diagnosis was correct.
