Goo Stopper
Have a number of joints to do with epoxy, so I'm wondering if a bit of Johnson's paste wax around the seams is sufficient as a resist to prevent staining of the wood with squeeze-out.
tia
Goo Stopper
tia
All I could think of, Mark
George Colonel's Workshop-Havertown PA
was Pepto Bismol.
George
Why not call the manufacturer?
I can't remember what joint I did on what, but the chemical reaction going on when epoxy cures seems to be pretty fierce, and ate through the resist I used - which I now forget.
Not much use, I know - but I think it's worth calling the manufacturer to ask, if you have the time to wait for Monday.
Squeeze-out, not pinch-off.
Time
Got that and plan on it anyway as I'm using a fast hardener and the stuff's still rubber (in thin section) after almost 4 hours. The bulked sample (wood flour in same mix) set up faster, but it's not hard by any means. Mix was by digital scale so I'm thinking my hardener made be going bad. I'll see what System Three has to say tomorrow.
Should do...
John in NM
But test it first.
I have an epoxy mixing board that gets a regular waxing, goo comes right off. I think smooth is as important as waxed, because if it gets too dinged up by the chisel I use to pop off the epoxy, the stuff sticks better.
Re: Goo Stopper
FredD
Johnson's Wax will leave a color of it's own.
When I want nothing to stick to the adjacent wood I use a Block of Paraffin wax available everywhere canning supplies are sold and it is far easier to control where it goes then paste wax
FredD
Hardener should not go bad.
Ray - Middletown, IN
May be the cooler weather is retarding the mix. Sometimes it takes 18-24 hours to set up hard in cooler weather.
I've used tape next to the joint for squeeze out to spread onto.
Ray
Re: 4 hours is not long for fast...
Rick L
I buy System Three epoxy gallons at a time. It doesn't go bad. Fast isn't to be confused with 5 minute epoxy. 5 Minute isn't as strong as the regular Fast, Slow and Medium. You should download the manual on the stuff. 3/1 mix for the Regular versus 1/1 for the fast. Had one guy one got the ratios mixed up...
In the cold weather the components can cloud up. We store them in the room with the boilers as our shop can go down to 50 degrees at night. Higher temps set the epoxy faster.
Tech Support Says . . .
That since I was mixing by weight, I cannot use the volume proportions of 2>1.
Instead, I'm to use the weight-mix ratio of 100 parts resin to 44 parts hardener. When I mixed 0.4 oz resin with 0.2 oz of catalyst I actually added too much hardener. Picky picky!!
[Tech also said the more I mix at one time the less chance of an error.]
So I'm now calibrating a little digital scale that works to 1/100th of an ounce.
Next time around, include Epoxy
Keith Newton----Little Rock, Arkansas
in the heading. I don't do Goo, but I use a lot of epoxy.
I use masking tape, then finger in or off, then peal the tape before it cures.
Aside from getting the ratio right, temperature is VERY important. Most epoxy will not cure without it. In Winter, I have trouble getting my shop warm as I would like when the temp is really low.
After measuring the two parts, I usually hold my mixing cup under the hot water tap while stirring. I then mix in the filler, and spread.
After the project is together, I set up a ridge board, then drape a tarp over the project, then set a little space heater blowing under the tent to keep it warm.
