Kitchen Message Unit
JimG
I want to add a message unit to the side of the Pantry I am building. I want the message center to turn out something like the one below (just the message center, not the cabinet). What is a good backing material: I am concerned that cork will "chip" over time. If you do suggest cork, is there a certain kind/quality/thickness/etc that I should use?
Thanks, JimG
Re: Kitchen Message Unit
Stuart Johnson
What about a metal white board with magnetic thumb tacks?
FredD
Yes , Cork is the premier Bulletin Board material .
What you need is not the Cork in it's natural state, which will chip and crumble as you fear , but Cork that is ground up fine and recombined and glued to a Burlap type cloth and a quarter inch in thickness for Bulletin Boards.
Apply over a Plywood or Masonite back with or without a Frame
It comes in rolls , sometimes hard to fine and fairly expensive , but well worth the results you get using it.
FredD
Check out cork flooring
Cork flooring tiles might be a good solution. You can pick them up locally or buy them online. I've used sheet cork for lots of projects, too, but the thick stuff is expensive. For bulletin boards, I usually get thin cork in a roll and laminate it with contact cement onto Homasote board.
Bill Tindall
I have something similar and used a fine grained cork designed for bulletin boards. It has held up well and if you design it to be replaceable it won't be a burden to replace it every 10 years.
I don't think it looks as good but the magnetic white board is functional. I turn cute little doodads and embed magnets in them to spruce up the white board and refrigerator.
Re: Kitchen Message Unit *LINK*
Dave Paine
If you want another option of being able to use magnets without the white metal panel, Lee Valley sells a magnetic paint. Apply this on drywall or any surface, then paint over to desired colour. I did this on a wall where I did not want to see a normal message board, but can use magnets to hold things up.
http://www.leevalley.com/US/wood/page.aspx?p=52114&cat=1,250,43298
JimG
Thanks, everyone. I've been looking at the different ideas. I've never heard of Homasote board.
I'm curious, Bill, how did you make it "easily replaceable"? Did you hide the mounting hardware?
Thanks again,
JimG
Homasote...
...is compressed cellulose fiber board, sold in 4 x 8 sheets and not expensive. It makes a great bulletin board all by itself with just a layer of fabric glued to it.
Google it; you'll find a wealth of information including where to buy it.
Lee Grindinger
Out west
Lee Grindinger
Out west it may be called Celotex..., same stuff.
Re: Out west
Howard Norman
Jim, like you I have never heard of Homasote but I am familiar with Celotex. I like the idea of using fine grain cork myself.
Clint Searl
Re: Homasote...
Clint Searl
Homasote also makes a great floor pad in front of the workbench. Easy on the legs and dropped tools, and lasts forever. I've had the same sheet in front of my bench for the last 16 years.
Clint
Clint Searl
Re: Out west
Clint Searl
I think celotex is made of cane fiber while homosote is made of wood pulp, which is much more durable.
Clint
Actually, ...
.... Celotex isn't the same. Homasote is denser and less flaky, so it's stiffer and tougher than Celotex.
to make easily replacable.....
Bill Tindall
frame it. Apply to a backing that will accommodate push pins(my cork was not very thick) (I used fiber insulation board ), apply this assembly to the wall and then frame with a molding piece. the molding could be applied with trim screws, or just lightly nail so it can be easily pried off.
Lee Grindinger
Standing corrected..., thanks guys.
Lee Grindinger
Knew a guy who made one with coated 18ga. steel glued to a piece of hardboard. Neat thing was he used a bunch of magnets attached to dowels of varying lengths; short (1") for "I'll do it some day" to long (4") for "Stuff that must get done before sundown". He could then just look at the board to see if he'd forgotten something important or there was a message he had to read before he went for that after-work brew.
Clint Searl
Clint Searl
I guess being nagged by a bulletin board isn't as bad as it could be.
Clint
Jim DeLaney, Austintown, Ohio
Re: Homasote...
For smaller pieces, use a 2 X 4 foot ceiling tile. Pretty much the same composition as homosote.
