Milling Pressure-Treated Lumber
Steve Bellner
I need to repair the railing on my 11-year old deck. One of the boards has split, and I noticed after all these years the railing was not installed "properly." The railing consists of a top cap and bottom rail, infilled with machined ballisters. The ballisters were attached to the top cap directly. I prefer a sub-cap, with a top cap attached to the sub from the underside. But I digress...
The original installation was probably CCA and was milled with a bottom groove and beaded edges. This product is no longer available, but it's a simple profile to reproduce from a 2x4. The wood I picked up today is ACQ-D treated southern yellow pine, and must have 20+% moisture in it. It's literally wet to the touch, and weighs a ton. How dry should I let this wood get before I start milling, and how long will it take to dry? I've got it inside at about 68 deg F. and 50% RH. Any tricks on how to keep it from twisting and bowing while it drys? I've got both ends in a press and I have a piece of angle iron clamped to the middle of four boards suspended on a pair of sawhorses.
By the way, I think what now passes for No. 2 grade would have been scrap wood a couple years ago. It took quite a bit of digging to find four boards that weren't loaded with loose knots and spikes. I haven't done deck work in quite a while, and I was very surprised at what passes for No. 2 these days. And before someone reminds me, I am aware of the precautions needed to be taken when working with treated lumber. Although I think the ACQ is probably a lot safer than the older CCA, I think it it probably still prudent to control and isolate sawdust and shavings from this wood.
