REAL MILK PAINT
"Houston, We Have a Problem"
My son dickered himself a deal on a dining table figuring that Dad could help him "fix" it.
The table, alleged to be all "quartersawn white oak", came with a 24" leaf, but was sans two legs and a bit shop-worn around the edges.
"Dad, do you think "we" could make legs and make this presentable? She (bride) really likes it."
"Sure, but how much?"
"Retail $4,800, but I've got him down to $275." [What's not to love, eh?]
So the table gets picked up and dropped in my shop, where i discover that while it is, indeed, white oak, only the two legs are quartersawn (the rest being flatsawn).
Top is made in two sections with the boards running widethwise. I examine the thing and find that both the extension slide and supplemental reinforcing pieces are screwed into each board, effectively locking them in position and preventing any movement. As the humidity in the house is now dropping a bit, my son's "new" table has started signing to me. Yeah, the wood is trying to move to adjust to a new EMC but the slide and braces are not wanting to let go.
Here's a pic to give y'all the idea.
I'm thinking that I should strip off the bracing and slide and modify the screw holes to slots to allow the top to expand and contract.
Impressions, suggestions?
Thanks
Re: "Houston, We Have a Problem"
Or maybe two problems
for some reason your picture's not coming through, even when I go in as an administrator. Maybe try again. Periodically, for some reason, pictures seem to get lost in the electrons.
steve mackay
I've "fixed" a lot of stuff and I think you're right. And I'll bet you're going to find even more to fix when you "open 'er up". I've heard it called a "tear down" on those house flipping shows.
Do you figure there's two seventy five worth of lumber there ?
Clint Searl
Run down to IKEA....
Clint Searl
and let them pick out a new one that Dad pays for. It'll be a win-win. :D
Clint
Brint in Richmond, VA
No suggestions - just thanks for a great story. ;-)
Retry
he he
I've got a source for QSWO at about $2/bf. Might be a C-notes worth of wood in this thing. The two legs that did come along use fixing boths that weren't even centered in the stock. One I'll use as a pattern, the other goes in the fireplace ;)
charlie belden
At least ovalize the holes - though slotting them would be preferred. Or you could go with Z-clips or
figure 8 "washers". Table sawing in a groove for the Zclips would be easier than making room for the
figure 8 washers or routing a bunch of slots.
George Colonel's Workshop-Havertown PA
Hello Mark,
Ship that table to Houston. Yes, by all means remove the screws which bind everything together. Before doing anything else, I'd wait a bit to see if the wood is stable. Warpage may "table" further action.
George
Knew I Could Count On You, George
to bring the appropriate motion to the floor!
LOL ! . . .
steve mackay
Probably lucky you have'nt found any partical board in there somewhere !
Col., you could dine out on that pun for days
Actually . .
After having removed all the extras, the two sections of the top remain flat, and there don't appear to be any fractures from out of order wood motions.
The extension slides will have to have their fixing points slotted, But I'll most likely make new cleats and use "Z" clips along with an anchoring screw.
All in favor, hold your piece!
