THE WOODRAT IS BACK!
Pentacryl for large projects?
DizD
Going to be working with a company which wants to use some 12' small peeled pine logs in an apperance function on a project and was going to recommend treating with pentacryl to stabilize the wood. Anyone had experience using this on large pieces - soak or brush, concentration to use, etc? I've only read about the stuff, never used it.
Re: Pentacryl for large projects?
Rick L
Rick L
http://www.preservation-solutions.com/index.php
Call these folks.
I've seem examples of small pieces of end grain cross sections of trees and it seems to work well. We just did a sort of hybrid timber frame with pine logs for the vertical posts with timbers for the horizontals. Did use anything special except for Moldex products...mold inhibitor and clear protector for the finish that doesn't look like a finish. There has been some checking as expected and will be more as the house is sealed up. It's nature.
I assume you want to have an unchecked log!!!! Sometimes you have to do the actual research. Personally I don't beleive it until I've seen it myself.
