Cleaning "dirty and greasy" wood?
We're refinishing our kitchen cabinets. Lots of stripping (rah).
Anyway, the tops of our cabinets were NEVER finished. Just bare wood - and dirt and probably kitchen grease. We are finishing them. The trouble is CLEANING them. We've just tackled the ones over the stove so far.
My protocol has been:
1) Vacuum
2) Sand with 60 grit
Repeat several times
3) Liberal applications of 409 (we're trying to get rid of all of ours followed by scrubbing with paper towels
4) Dry
5) Sand from 60 grit to 220 grit with vacuuming between each grit.
Needless to say, this is a PITA.
Does anyone have any other suggestions on how to proceed??
TIA.
Re: Cleaning "dirty and greasy" wood?
Scraper?
Have you thought about trying a card scraper?
Tom
Murphy's Oil Soap? If I recall correctly, the advertising talks about it being used on church pews and the like; so it works on wood.
Trisodium phosphate may be a little fiercer than you want (but if you try it, get the real thing; there's a TSP substitute out there that my son says is worthless).
I've had some very good luck degreasing things with true turpentine, but it's an expensive way to go - and probably not the best fumes to have running around in the house this time of year, when you can't open windows.
Vacuum. Scrub with Murphy's and a stiff brush, and wipe dry with cloth towel. Rinse-wipe with clean water and wipe "dry." Wipe with DNA to accelerate drying. Next day, seal any residue in with a coat of dewaxed shellac (SealCoat is fine) but do not "work" the coating. Beyond that is up to you.
Dale Lenz
I second the shellac sealer
Dale Lenz
Clint Searl
Clint Searl
When I redid our cabinets, I just overlaid the tops with 1/2" ply and added a decorative molding around the edge. Nice place to display Ertl toy tractors or pottery or your old toaster collection.
Clint
Clarification....?
Bill Tindall
I am confused about the problem. It does not involve stripping the face frames....correct? The problem involves the "top" of the cabinet. This would be the top of the upper units, up where no one sees, not the counter top of the bottom units.....correct? So, if it indeed is the top of the upper cabinets where no one sees, what do you want to accomplish? You seem to be expending vastly more effort than is justified by the problem.
Making the presumption that you want to coat this area so that it can be washed in the future, then seal it with a product designed for this task- solvent based Kilz. Follow directions on the can for surface preparation, or call their customer service line and ask. After it dries, sand with 220 and put on a top coat of solvent based enamel paint.
As far as the best way to remove grease from wood, I would use paint stripper, especially since you are already using it on the face frames.
That may be it!
I hadn't thought of using the paint stripper. As you say, I already am using it for the face frames.
The LOML wants to use this area for auxiliary storage. She has a number of Longaberger baskets as well as some other things.
paul in AZ
I'd go with Clint's idea.
Why take the time and trouble to strip it clean if nobody is ever going to be looking down at the surface? Seal the gunk in with shellac if you will and cover it with nice clean plywood that can be painted and thus easily cleaned.
Re: Best is Windex
Janet Bequeaith
It's time for a woman to chime in--good old fashion blue Windex will take off grease in no time, as will amonia but, with amonia be sure to not mix chemicals, and get a fan going on high.
Windex is safer, use it.
TSP will do it but, it will also take the skin off your knuckles so, wear rubber gloves.
BTW, Windex is the only thing that will take printer ink off of oak floors--ask me how I know that?
Have fun, been there, done that.
Janet
suggestion going forward
Myra Fox
I know that you are going to finish the top surface so it can be washed. Easier than washing is to cover that top surface (which cannot be seen anyway) with a 2 or 3 sheet layer of newspaper. When it's time to clean, throw away the dirty and replace.
If the fumes don't explode and
Gary Smyth
your skin can be protected I'd wipe it down with lacquer thinner and 000 steel wool. Wear a suitable mask as it will overpower you in quantity and irritate your nose, but it will dissolve the grease and some finishes, dry fast, and is quick to do again if necessary. Protect yourself and becareful of fumes.
Bill has the answers.
Howard Acheson
One other thing to keep in mind is that using any solvent that dissolves oil will also thin the oil promoting its absorption into the wood. Using an acetone, lacquer thinner or other solvent will not effectively clean the surface.That's what makes it difficult to clean old wood. Kitchen cabinetry is subjected to more contaminates than most anything else in the house.
FredD
I would forget the sixty grit.
TSP is the original degreaser for interiors, wear rubber gloves and apply with a large sponge like Cement Masons and Tile setters use.
It is fume-less , non-volatile and works. You only need the one pound box, any hardware and cheap.
If you have any left , have your Wife use about a Tablespoon full per Laundry load, it's the Phosphate that the government caused to be removed from Detergent, apparently worked to well , like DDT and Chlorodane, so now we are enjoying a epidemic of BedBugs, so much better wouldn't you agree?
FredD
